Old 12-12-2014, 12:09 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
jeep steering column swap?!?
i have read about people using jeep XJ colums in our trucks since they use U-joints instead of the old rag joint.
so in theory, i can get an XJ column with tilt and bolt it into my truck(and yes I will put the chevy steering wheel back on ).
I have been attempting to replace my ignition switch so the column is already almost out. figured I should upgrade to a tilt column but i want to keep it on a junkyard budget.
what other colums will work? like will an 80's S-10 column work?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 12-12-2014, 12:24 PM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: jeep steering column swap?!?
I found a video on Youtube where some guy explains just the steering shaft swap. not exactly bolt in but, straightforward. Im looking to swap the entire column
I dont know how to embed the video, yet...
https://www.youtube.com/watch?v=H9C4RdvjPNQ
Savannah, Georgia
Old 12-12-2014, 12:27 PM   #3
bucannon
Salty Sailor
bucannon's Avatar
figured it out
Savannah, Georgia
Old 12-12-2014, 12:40 PM   #4
slotard
Hmm, I'll have to consider doing that.
Speaking of tilt columns and ignition cylinders, can they be removed without the key? I'd like to upgrade to a tilt column but if I can't get the cylinder out of a junkyard one (to install a new cylinder), it's a different story...
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-12-2014, 01:24 PM   #5
bucannon
Salty Sailor
bucannon's Avatar
yeah, you remove the lock cylinder by pulling off the steering wheel. you remove several screws and plastic components and you are at the lock cylinder, which comes out with one screw. no key is needed, just patience.
but does anyone out there know what vehicles other than the full size trucks/blazers etc i can pull the tilt column from that will bolt in?
Savannah, Georgia
Old 12-12-2014, 02:03 PM   #6
riz
What year Jeep XJ has that steering shaft?
RIZ
riz is offline   Reply With Quote
Old 12-12-2014, 02:05 PM   #7
slotard
On non-tilt columns it needs to be unlocked so that's why I was checking. You also need to punch a hole in the casting with a screwdriver to get it out.
I haven't heard of other swap options, hopefully someone knows some.
1973 C20, 350/350
Old 12-12-2014, 07:32 PM   #8
bucannon
Salty Sailor
bucannon's Avatar
RIZ
accordind to the video its mid 80's to early 90's cherokee, which is to me is the run of the XJ. now i have heard on pirate 4x4 that it may only be limited and grand cherokees but i dont know for certain.
Savannah, Georgia
Old 12-12-2014, 07:44 PM   #9
GMC Guy
GMC Guy's Avatar
just pulled one from a Pick N Pull, what a PITA to get to... makes me appreciate all the wrenching room we have even more.
And of coarse, it wasn't til after i got it out that i noticed the rubber insulation was chewed up
doesn't feel like there's any play, maybe it'll be alright. Cost was $13.99... we'll see if it was worth it.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 12-12-2014, 07:48 PM   #10
slotard
I read that Grand Cherokee columns don't work.
Does it just help reduce slop or is there some other advantage? Mine seems pretty tight...
1973 C20, 350/350
Old 12-12-2014, 10:29 PM   #11
sgr60
I bought one on ebay this week - still some more for sale:
http://www.ebay.com/itm/141470182928...%3AMEBIDX%3AIT
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 12-13-2014, 11:06 AM   #12
Ski-me
Ski-me's Avatar
I just pulled one from a standard Cherokee (not Grand Cherokee)....kind of a pain to get it out. Once out though, not too bad getting it into the Blazer. I only did the steering shaft, not the whole column. I just wanted to get rid the rag joint and tighten up the steering. It worked out quite well and I'm pleased with the result.
There are two different versions of XJ shafts too.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 12-13-2014, 03:00 PM   #13
bdiamond
Yeah, Grand Cherokee will NOT work. 84-01 Cherokee XJ Jeep is the one you want. Be careful pulling your existing shaft. The clip that holds the brake lines together under the master cylinder is sharp as a razor. Ask me how I know....I'd remove it before I tried the swap.
bdiamond is offline   Reply With Quote
Old 12-13-2014, 06:01 PM   #14
sgr60
I just installed mine along with a new steering box. The shaft went in great, just having some problems with the new box. Have a leak at one of the lines and there's a bunch of air in the fluid.
'84 K20 350/465/208
Old 12-13-2014, 07:31 PM   #15
Ski-me
Ski-me's Avatar
I'm in the middle of mine (04 Yukon XL)....new pump and box. Although mine is newer, one of the suggestions I got was to jack the front end up in the air (both tires) and with the engine off, cycle the steering about 20-40 times. Mine is a hydroboost system but I would think the same method could be applied. Just check periodically to be sure the reservoir doesn't run out.
- Jeff
Old 12-13-2014, 08:01 PM   #16
sgr60
I read that too - just completed it and it seems to be all good. Going to take it out for a drive now.
'84 K20 350/465/208
Old 12-13-2014, 08:49 PM   #17
franken
This thread inspired me to run off the the local picnpull and snag a shaft for $12 and tax. 2 bolts on the shaft, 3 on the steering box and off it came. Since the front bumper was gone I figured dropping the box was easier than unbolting the column or trying to collapse the shaft.
Snagged an NP205 shifter for $5 as well.
franken is offline   Reply With Quote
Old 01-08-2015, 05:40 PM   #18
bucannon
Salty Sailor
bucannon's Avatar
awesome, got any pictures?
Savannah, Georgia
bucannon, chevy truck, column, xj jeep
