Old 12-14-2014, 12:07 PM   #1
ACII
ls1 harness how to protect the wires
Hy all
GM is originally using a corrugated tube for protecting the wires.
Sorry but i am not sure how u call it in english.....i mean those black flexibel plastice tubes...
My english translater calls it "corrugated tube"
So after i have stripped the harness....i want to use the same tube, but i am just wondering if the sharp edge (where the tube is slotted) wont hurt the where the cables come out of the harness.... ???
Of course i have tapped the cables before i put it in the tubes... but i guess of all the vibratons of the engine the sharp edge will cut it through...
I hope u understand what i mean !! :-)
Thanks for ur help
CU
Achim
ACII is offline   Reply With Quote
Old 12-15-2014, 08:15 AM   #2
Chrysis
Chrysis's Avatar
Re: ls1 harness how to protect the wires
Here it is frequently called split loom. Most of the time you will see just a few extra layers of tape where your wirirng needs to exit the loom. If you want a really clean look you can get something like this. Just make sure it is engine temp safe.
http://www.cableorganizer.com/wire-l...-loom-tees.htm
Chrysis is offline   Reply With Quote
Old 12-15-2014, 03:24 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There are different types of this stuff that all do the same job. You can also look at "braided loom" which looks like a Chinese Finger Trap, and is a bit softer and more flexible than the other stuff.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-16-2014, 12:29 PM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I use Techflex braided loom on all my harnesses. You can get it in the solid "finger trap" style like Brew mentioned, and you can also get a split version of it.
http://www.techflex.com/land_genpurp.asp
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
