Old 12-16-2014, 03:12 AM   #1
68shortfleet
LSx fuel supply without AN fittings.
Looking to see options for building a LS fuel supply system without an extensive use of AN fittings.
Basically all factory vehicle fuel systems run a short section of flexible line near the tank and a short section near the motor. That is what I want.
What kind of options do I have? Suggestions? Pics/part numbers?
68shortfleet is offline   Reply With Quote
Old 12-16-2014, 03:38 AM   #2
scottybaccus
scottybaccus's Avatar
Re: LSx fuel supply without AN fittings.
I used an in-tank pump, on the pick-up for an '87 TBI truck. It just uses push on hoses for supply and return. You do want the proper hose clamps for efi. The best hose I found is Gates Barricade EFI hose. It comes in two pressure ratings. You want the higher. I have hard line down the frame rail, with a fuel filter halfway, turning up just behind the starter. You can use the same hose from here, to the fuel rail. You will need a barbed fitting that fits the fuel rail. Most parts stores have them.
Be sure to use a heat sleeve as the hose crosses anywhere near the exhaust.
I also used a tool called Clamp-Tite to apply stainless safety wire hose clamps, rather than worm drive, or worse. You can apply heavy heat shrink, such as that used on AC wires that feed your house, over the wire clamps to make them look more factory. Google the tool.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-16-2014, 01:12 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I always add this; if you plan on taking the truck on any NHRA drag strips, having more than a foot of rubber hose (even the EFI approved stuff), will fail tech.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-16-2014, 11:30 PM   #4
lynnfield
The Waco Kid
lynnfield's Avatar
You can check out what I did here: http://67-72chevytrucks.com/vboard/s...=585899&page=5
Posts 107-118, 145, & 154
lynnfield is offline   Reply With Quote
Old 12-19-2014, 07:43 PM   #5
yossarian19
I think I mentioned in my build thread..
What i used was Dorman nylon fuel line and fittings. It's found in a lot of OEM applications, it's cheap, it's easy to work with. If you wanted you could adapt it to a run of steel line along the frame and use the nylon to get to the rail. Any 3/8 barbed fitting will work - no need to buy special tools, either - just take your time and it all goes together pretty easy.
If I were building a race car or street / strip machine I'd go AN. Since I'm not... the nylon line was perfect.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 12-19-2014, 10:39 PM   #6
portworks
Very easy to do with the blazer tank and modified stock sender/pickup assy and an intank pump . Using stainless hard line, with compression fittings and push lock hose !
I will have a complete new intank pump assy for sale very soon. Upgrading to twin turbos !
portworks is offline   Reply With Quote
Old 12-21-2014, 03:59 AM   #7
68shortfleet
After I posted this thread, I talked to a friend of mine that has a repair shop about this. He also suggested the Dorman fittings and steel/stainless line for my build. He stocks the Dorman fittings and has the tool to make the special flare for the fittings.
Exactly what I was looking for.
And I agree with you, race/strip car would definitely be getting AN fittings.
Old 12-21-2014, 04:03 AM   #8
68shortfleet
Lynnfield. You have an amazing build going on. Your build ideas appear very close to how mine will be done. Things like factory looking fuel line plumbing and re-routing wires in the bulkhead connector so it can still be separated. It's all in the details..
Old 12-27-2014, 10:34 AM   #9
mattcrp1
mattcrp1's Avatar
The Dorman nylon fuel line worked well. I also added the summit heat sleeve to the section that transitioned from the frame over the planned exhaust routing up along the back side of the transmission for added protection.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 12-27-2014, 11:58 AM   #10
Bowtiguy
Bowtiguy's Avatar
http://www.corvetteforum.com/forums/...uel-rails.html
This is a link to how I converted my SS factory hard lineson my C6Z to accept AN line to the fuel rails. If the "russel" part would have failed while I was road racing, it would have been all over.
Here is a link to the MFG part #
http://www.swagelok.com/search/produ...t=SS-600-6-6AN
Bowtiguy is offline   Reply With Quote
Old 12-27-2014, 04:22 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The Russel part with aknowledged failure is the early part # PTC fittings, not any of the compression fit or flare fit parts. The failure was due to poorly designed inner retaining clips, and not any inherent failure of a brand. It has since been replaced with a capped clip that can't really fail.
Old 12-27-2014, 06:30 PM   #12
Bowtiguy
Bowtiguy's Avatar
that's good to know. My issue was over 4 years back. For those not going with swage lock or another option, is there a way for anyone to differentiate between the bad and "revised" part?
Old 12-28-2014, 12:57 AM   #13
Oklahoma_k5
Anybody tried using something like this?
Amazon.com: Dorman 800-300 Nylon Fuel Line Repair... Amazon.com: Dorman 800-300 Nylon Fuel Line Repair...
$200 to have all the fittings that might be used in one box is pretty enticing.
Factory uses plastic lines so???
is this what you are talking about Matt
Oklahoma_k5 is offline   Reply With Quote
