Old 12-17-2014, 11:34 PM   #1
57halfton
2 wheel drive to 4X4
would it be realistic to convert a 2 wheel drive 72 Chevy 1/2 ton to 4 wheel drive ?
57halfton is offline   Reply With Quote
Old 12-18-2014, 01:43 AM   #2
newstedcomeback
newstedcomeback's Avatar
Re: 2 wheel drive to 4X4
I'm doing the same thing right now. I have a 71 and I'm in Santa Rosa. the easiest way is to swap the frames. I picked up a frame from Livermore a couple months back. here is a link to one that in Petaluma. it already has a 4' lift, comes with 3/4 ton dana 44 front, 14 bolt rear and a 4 speed/NP205 combo. the guy says it has dana 60's front and rear but its a dana 44 and a 14 bolt. if you dont want a 3/4 ton I could help you with all the parts to change the axles to a 6 lug, I have tons of extra parts. this frame is the best way to go. swap your parts over and go. everything is bolt on.
http://sfbay.craigslist.org/nby/pts/4802493989.html
If you try to convert the 2wd frame, It will require a ton of fabricating and welding the frame/ front suspension. The frames are different widths in the front. I would go the easy route and pick up the frame.
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877
2018 Silverado 1500 5.3 LTZ Z71 - daily driver
2019 Tahoe Z71 5.3 - (Wifes daily driver)
newstedcomeback is offline   Reply With Quote
Old 12-18-2014, 03:52 AM   #3
andrewmp6
Is it a long bed or short bed truck?If its a short bed sell it and use the money to buy a 4x4 truck.If its a long bed looking to a frame swap.
andrewmp6 is offline   Reply With Quote
Old 02-21-2015, 06:43 AM   #4
El Dorado Jim
definitely start with a 4x4 frame,or pick up a beater donor truck,then you have all the parts you need..me and my son converted his 70 gmc longbed 2 wheel drive to 4 wheel drive,we picked up a 4x4 frame and had to find all the pieces at swap meets,pick n pull, and local paper , we needed springs, crossmember for motor,etc, used axles from a 74 3/4 ton,had to move the spring perches and shock mounts on the rear axle, had to find drivelines, trans/ transcase, etc....took awhile to find the parts, when we were almost done,we came across a donor truck fairly cheap,but didn't need it by then,would have made the job a whole lot easier.......I will try and post pics of his truck soon
El Dorado Jim is offline   Reply With Quote
Old 02-22-2015, 05:58 PM   #5
El Dorado Jim
a couple of pics of my sons 70 gmc this is a 2 wheel drive to 4 wheel drive conversion, still haven't figured out how to post pics right side up....
Old 02-22-2015, 06:02 PM   #6
El Dorado Jim
one more pic
