Hooker Header LS Swap Mounts?
I met a guy with a 89 CCLB with a LQ9 6.0 swap. He said he used Hooker Header LS Swap Mounts. Turns out Summit sells them, and they look clean! I have a gift card so I'm thinking about grabbing these instead of the bolt-together Dirty Dingo mounts. The only thing I don't know about is if I can run them on my truck. I plan on running F-Body Manifolds. The way the hooker mounts work is you use the mount pocket that bolts on the original small block and it bolts to the adapter plate bolted to the LS Motor.
Looking for reviews, anyone seen these or used them successfully? |
Re: Hooker Header LS Swap Mounts?
are they the block hugger shorties?? if not, look into them
oh wait, your talking about the mounts by Hooker Headers, nevermind
Yes, the LS swap engine mounts by Hooker. I was gonna do DD but between the cold weld issues and then the new all bolt together mounts, I wasn't feeling it. I'm using stock exhaust manifolds from a 02 Camaro SS. I'm trying to find someone with experience with these mounts. They have all kinds of options, to move the engine closer to the firewall or closer to the radiator.
Anyone? |
