Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 12-28-2014, 07:40 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
'71 Orig AZ SWB frame with complete drive train
Doing a frame off restoration on this '71 SWB from Arizona. Going with new custom chassis and doing an LS(x) swap. I will be removing the body and looking to sell this original frame with complete drive train. The frame has no rust through and cab mounts are in great condition. Being a '71 it has front disc brakes. Engine is a 250 cu in, with 3-speed manual transmission. Also has front and rear sway bars installed. Bolt pattern is 5 on 5. Coil spring rear suspension. Currently no pictures of just the frame as the body is still installed, but you get the idea. There will be no title with this frame, since I will be retaining the original title for my build, so Bill of Sale only. Thanks for your help.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 12-29-2014, 02:50 AM   #2
68bowtie
68bowtie's Avatar
Re: '71 Orig AZ SWB frame with complete drive train
assuming all parts are original-ish (not recently rebuilt) i would say $700 to $800 for the frame and suspension plus whatever value of the eng/trans on top of that. i assume wheels/tires excluded... not sure on engine value but if someone can test drive everything before you tear into it that will get you top dollar.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 12-29-2014, 10:46 AM   #3
derotoreut
derotoreut's Avatar
This is an all-original Arizona truck. Vintage air was added to it, but other than that it's original and very solid. Wheels and tires will be sold separately.
~ Dan
Old 12-31-2014, 02:33 PM   #4
dubds10
Stalker Nate
$500 bare frame, $800 with drivetrain if good running condition. If engine is a newer rebuild though I'd sell seperately for more. Can try higher though since you're on the East Coast.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
