01-04-2015, 12:20 AM | #1 |
Converting from power brakes to Wilwood manual master cylinder
I'm working on converting my 72 from the factor power brake booster and MC to a manual Wilwood tandem master cylinder. Since the truck is running I'm wanting to make sure I have all the parts that are needed before I start tearing it apart.
What is required to adapt the Wilwood MC to the factory pedal (rod end, threaded sleeve, etc)? Will it bolt to the bottom 2 factory holes and have everything line up? Do I need to cut any of the holes bigger? I did a lot of searching and this was the best picture I found of an install showing the MC being mounted to the bottom 2 holes but the owner listed the truck as originally being a manual brake truck.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
01-04-2015, 12:18 PM | #2 |
Re: Converting from power brakes to Wilwood manual master cylinder
Interested in more info on this . I was getting ready to do this or just buy a mud 70's vette mc
01-05-2015, 09:24 PM | #3 |
I have my wilwood master. I didn't install it yet but I have done some mock up. I am going from power to manual. The bolt holes are the same and the hole in the firewall is larger so it should be a good fit. I used a 15/16 master and it comes with the rod for the pedal. This is what wilwood recommended with my setup. 14" rotors in front and 13" in the rear.
01-09-2015, 12:54 AM | #4 |
I am in the middle of my power to manual conversion and went with a 72 corvette master. Since the truck had power I have to get a manual push rod from our local C10 parts guy. So far the hardest part has been bending the line from the master to the Wilwood adj prop valve.
01-09-2015, 08:12 AM | #5 |
Do to u have a part# for the correct pushrod ?
01-11-2015, 10:36 PM | #6 |
Roto Reuter thats the name...
Interested in this as well. I'm planning to do the same with my Wilwood master and 14" brakes (front and rear). Subscribed.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-11-2015, 11:15 PM | #7 |
Here is a picture of what I did today. I removed the old booster and the new master bolted right up to the old mounting holes. Firewall hole was good too. The pushrod that came with the master is too short so I need to extend it. Pretty easy.
01-11-2015, 11:16 PM | #8 |
Here's another
01-12-2015, 12:01 PM | #9 |
I'm assuming you're going with front and rear disc brakes? Did you go with an adjustable Wilwood proportioning valve?
01-12-2015, 12:38 PM | #10 |
01-20-2015, 08:33 PM | #11 |
Was curious if previous members from earlier post completed their wilwood mc kit from power to manual? I'm getting ready to do the same thing on my 72 converting from power to manual. I currently have 13'' front cpp rotors with 12'' rear cpp rotors. Do you guys know what bore of mc to use on my application??? Any feedback from install would be great!
01-20-2015, 10:29 PM | #12 | |
If your going to use wilwood just call they're tech support line and they will tell you whats best for your application. And give you a part #. That's what I did. |
01-21-2015, 11:33 AM | #13 |
Okay thank you! Have already installed mc? Any tips?
01-21-2015, 11:42 AM | #14 |
It's pretty straight forward. If your going to get a pro portioning valve get the kit. It has a bracket that bolts up to the holes in the firewall and it comes with the lines pre bent from the mc to the prop valve
01-21-2015, 05:31 PM | #15 | |
01-21-2015, 09:41 PM | #16 |
After installing mc with combination valve, do you have to replace hard lines from front and back of truck and bend and glare them to fit the mc? Or does oem lines go into mc/combination valve?
01-21-2015, 10:57 PM | #17 |
You might be able to make the stock lines work but astedically it won't look that good. The prop valve has a spot for both front lines and one for the rear. I'm redoing all the lines cause mine were kinda shotty looking. As far as the fitting size I'm not sure cause I cut mine off. But still 3/16 tubing I believe.
01-22-2015, 07:17 PM | #18 |
Curious how these work, as in how much effort is required to activate brakes? They are supposed to replace power serup but not have much effort as stock manual, correct? The stockers in non-power were not much fun for me.
"You can take the man out of PA, but you can't take PA out of the man" |
01-22-2015, 08:16 PM | #19 |
I've been looking at this master what you guy as think ?
http://www.carolinaclassictrucks.com/MC1312A.html |
01-22-2015, 09:27 PM | #20 |
I'm not quite sure how they're going to work yet. I haven't got mine buttoned up yet. But I've heard that it's not much of a difference then power with the big brake setup. I didn't want the bulky booster under the hood.
01-23-2015, 01:47 AM | #21 | |
11-22-2015, 12:55 AM | #22 |
I bought a 1970 GMC C-20 and the previous owner said he used parts from a 1972 Chevy truck to convert it to disc brakes in the front. The Brake Pedal is very high, is that because of the pushrod is the wrong length? The Master Cyl. is new too and not sure if he used a 1970 Master that has a 1.125" Bore or 1972 that has a 1.250" Bore. Would the pushrod be the same for both Master Cylinders?
11-22-2015, 09:29 AM | #23 | |
11-23-2015, 03:10 AM | #24 |
This helps to explain some of the different size bores in the Master Cylinders.
https://www.youtube.com/watch?v=WxT9vLO6pOc |
