walbro external fuel pump and wix corvette filter/regulator
I'm helping a buddy with a 5.3 Vortec ls swap on a 85 c10.We have a 85 fuel tank and are using the walbro 255 external pump and the Wix 33737 corvette filter/regulator.We put a fuel gauge on the fuel rail and just hooked up a power and a ground to the pump and the fuel press pegged the needle on the gauge over 125psi.Shouldn't the fuel pressure regulator keep the pressure at the rated 55to60 psi.It is all brand new im thinking we have a defective regulator or are we over looking something.Thank you guy in advance.
![]() Join Date: Sep 2005
Re: walbro external fuel pump and wix corvette filter/regulator
How is the filter pumped? 3/8line is feed 5/16 is return filter should keep pressure at aroun 60 mine does using the wix filter regualtor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Yes thats they way its plumbed.But for some reason the fuel pressure at the rail pegs the fuel pressure gauge over 125psi.Would not having the fuel pump wired through the stand alone harness fuel pump relay have something to do with this.I wouldn't think so but I could be wrong?
Post a pic of how you have the lines hooked up if you can, it sounds like something is backwards. The 3/8 male fitting on the filter should be the feed "in", the 5/16 male fitting should be the "return", and the 3/8 female is the "out" to the fuel rail. If you have it hooked up that way and it's still pegging the gauge, you either have a bad filter/regulator or a defective gauge. I have seen cheap filters be bad out of the box, but never a Wix, does the filter have "Wix" stamped on it? Maybe a cheap one got switched to the more expensive Wix box, shady things happen.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
We double checked the the connections and all is right.Going to get another wix filter/regulator and put on this week.By any chance would the pressure be that high due to just hooking up direct power and ground and not going through the fuel pump relay in the stand alone harness.From my understanding the crank sensor sends a signal to the computer which then sends a signal to the pump making it come on when needed.I could be wrong this is all new to us as it is are first swap.My truck is next its a 87 so the fuel system will be different my motor in not returnless.
The wix filter will regulate the pressure, your still only supplying 12v to the pump even if your not using the relay.
It's alsways something.....
![]() Join Date: Nov 2008
It sounds like the fuel return line from the regulator to the tank is somehow stopped up or plugged.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Boosted Member
Could be a bad filter/regulator assembly. I've gotten more from WIX that were junk straight out of the box than I care to remember...but it was the other way around. Just enough fuel pressure to idle, and nothing more.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
![]() Join Date: Jan 2015
can you pull vacuum off the rail and see if pressure changes?
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
So we found the problem!The sending unit had a filter on the return tube on the inside of the tank restricting the flow.This is a brand new sending unit.
That part is on the vent tube inside the tank, are you sure you had the return hooked to the right line?
Yes it is connected right.We took the return off the tank and dumped it into a gas can and the pressure was 58-60psi.We dropped the tank pulled sending unit and found it so we took it off hooked it all back up and pressure was good.So definitely that was the issue.
#13 |
Bringing this back from the dead, I'm having exact same problem, going to pull bed this weekend.
#14 |
#15 |
Thank you 87squarebody, that did it.
#16 |
#17 |
BMW & ASE Master Certified
Oh my bmw ls swap, I had a corvette regulator crap out after 2000 miles... decided to machine down a 4 bar regulator and use the bmw filter which has 3x more filter media.
![]() Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#18 |
any more pictures ? how did you machine it down?
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
#19 |
![]() Just shows it machined down to fit the filter.
