Old 01-13-2015, 12:18 AM   #1
Thebrownturd
Bolt on exhaust?
Has anyone used a bolt on exhaust? If so are you pleased with it and where did you get it from. is there a brand or certain place that sell kits that fit well on a stock 4x4.
Thebrownturd is offline   Reply With Quote
Old 01-18-2015, 11:43 PM   #2
Big-Blue
Big-Blue's Avatar
Re: Bolt on exhaust?
Saw these at Summit. Haven't used any and some may be for coil springs. For these prices tho a muffler shop could custom build it for you I would think.
http://m.summitracing.com/search/par...del/c10-pickup
Big-Blue is offline   Reply With Quote
Old 01-19-2015, 12:27 AM   #3
Kinze
Pypes makes a direct bolt on 2 1/2in. system.
Stainless Works makes both a 2 1/2in. and a 3in. direct bolts on systems.
Kinze is offline   Reply With Quote
Old 01-24-2015, 08:15 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I put this on my 71 about 10 years ago. Going to use it on my 86 now.
http://www.heartthrobexhaust.com/manifolddualkits.htm
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-25-2015, 12:09 AM   #5
DWilbur
I bought a bolt on system from summit 2-1/2" stainless steel. I might be installing it in about two week. waiting for my frame to get power coated.
DWilbur is offline   Reply With Quote
Old 01-25-2015, 12:20 AM   #6
taylorbg
I installed a bolt on kit in my old 77 vette. Install wasn't too bad. Ended up taking it to shop and having them weld it together. Was worth the extra hundred. Too much rattles and leaks without the welds. Plus there are no nuts to come loose with welds. I went with the bolt kit over a fab shop because of the mandrel bends. Couldn't find a shop to do mandrel bends that wasn't stupid expensive.
I say do the bolt on kit only if it is mandrel bends, but have it welded after you get it together.
taylorbg is offline   Reply With Quote
