Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-13-2015, 03:35 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Lightbulb Tilt column retrofit into original column
I was replacing an ignition switch and ended up removing the entire steering column in my 86 Custom Deluxe. What started small is now a bigger project since i decided that it was time to swap in a tilt column!
I went to my local cash-n-carry and found a tilt column out of a 93 pickup that still had a key in the ignition, It was clean and easy to remove.
I do realize that i pulled a different body style column, so this is not a bolt in project. I plan to combine components of the two colums to make a tilt column in my truck. I will also replace the blinker/wipers switch to the correct for my 86 wiring harness.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
bucannon, tilt column
