Old 01-16-2015, 06:25 PM   #1
morethanstock66
morethanstock66's Avatar
Different Year model Rad Swap Question
I was trying to find some info on people who swapped different year model radiators in their 60-66 C10s. I'm looking to replace mine with one who's top would be level with the top of the rad support... Similar to the 67-72 C10 radiator fitment. The only one else I had seen was a 1st gen Camaro rad on a LS swap on this site, but I can't find that link again.
Has anyone else looked into doing the same thing?
I assume a 67-72 rad with the same formed hoses would work for a 60-66. Would I be wrong?
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 01-16-2015, 08:59 PM   #2
PGSigns
PGSigns's Avatar
Re: Different Year model Rad Swap Question
The 67 to 72 radiator is about 8" wider and will not go in it. You could have one built to do what you want.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-18-2015, 12:29 AM   #3
Chris Coufal
I am using a 67-69 Camaro radiator in my LS swap. I chose to use it because it fits better and looks more natural in my opinion. It is a few inches wider than stock, but a few inches shorter. It fits between the inner fenders with about 1/2" to spare on each side. Once mounted, it will sit flush with the top of the core support instead of 4" above it. Also once I mount it, it will be about 2" above the frame rails allowing me to connect the lower hose.
For mounting, I will be welding small tabs on that 1" space in the core support. I will be bolting directly to it with a rubber washer for dampening the vibration.
Chris Coufal is offline   Reply With Quote
radiator, radiator support
