Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-16-2015, 10:38 PM   #1
freezmcnally
freezmcnally's Avatar
another am radio question HELP!
ok. been searching but i dont seem to have the wiring spades listed as others do...or im confused...or both.
If i hook up power to the 12v spade and ground the radio...it remains dead when grounded. knob on/off makes no change
if i hook up power to the unmarked middle spade, it lights up when grounded.
everyone says hook power up to the one that says 12v. but it only looks to work when i do it on the middle one...so im confused. haven't even got to the sound part yet
Every new beginning comes from some other beginnings end
freezmcnally is offline   Reply With Quote
Old 01-16-2015, 11:28 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: another am radio question HELP!
Here's a picture of a radio wiring harness. Maybe it'll help. Looks like the 12V/power wire is at the end. Other 2 are speaker.
FirstOwner69 is offline   Reply With Quote
Old 01-17-2015, 10:57 AM   #3
BLT gmc
antennae must be hooked up or the radio will be quiet. I agree with FirstOwner69 on the wiring. Also if the radio is powered up with out the speaker hooked up(and the correct resistant speaker) you can quickly burn up the ceramic fuse in the output circuit. Bruce
BLT gmc is offline   Reply With Quote
Old 01-17-2015, 12:37 PM   #4
michael bustamante
michael bustamante's Avatar
what ohm is the oe speaker?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-17-2015, 02:21 PM   #5
FirstOwner69
8 ohm. Below is a link to the place that reproduces the correct speaker. The magnet on these is round and they supply a wood block that replicates the original magnet. That is required for mounting when the original bracket is used. I have one of these and it works great. This link also contains pertinent information.
http://www.turnswitch.com/speakers.htm
Old 01-17-2015, 02:37 PM   #6
michael bustamante
great thank you
1967custom
Old 01-17-2015, 05:46 PM   #7
BLT gmc
I will second that speaker. It is very good. Bruce
Old 01-17-2015, 05:59 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
x3 - US built and a good deal IMO, I used one in a K10. The owner has also refurbished OEM truck and van AM/FM radios for me.
Old 01-17-2015, 11:43 PM   #9
freezmcnally
it has two little speakers that were from the aftermarket 'replica' stereo. which i believe are 8ohm...i can't remember the company off hand now but its the common one that everyone buys as a modern replica. too lazy to go out to the garage right now to see.
i tried it with an 8ohm sony bookshelf speaker when trying all the connections. again, silence but lights up when grounded if i hook the 12v to the MIDDLE spade. if i hook it to the end one that says '12v' the radio does nothing. im thinking its dead, not sure how else to know. i thought maybe if it lights then there was a chance.
Old 01-17-2015, 11:46 PM   #10
freezmcnally
does it look like all the spades on that plug are evenly spaced. on the back of the stereo they are not. its a slightly wider gap to the one that says 12v. does it look like that on your plug too?
Old 01-17-2015, 11:55 PM   #11
FirstOwner69
The light is not an indication if the radio is getting power unless the left radio knob is turned to the on position. If not turned on, the light is off even with the headlights on. That's the way they made them.
EDIT: Your picture in post 1 shows only 2 wires. There should be 2 wires to the speaker as in the picture I posted in post 2.
Old 01-18-2015, 12:08 AM   #12
FirstOwner69
I zoomed in on the picture in post 2 in order to show the ends of the 2 wires that connect to the speaker. You can even see how these broke off the speaker.
Old 01-18-2015, 12:12 AM   #13
freezmcnally
hi. ya i took the picture so the spade markings could be seen...i didnt have all wires connected when i took it...sorry for the mislead.
this radios light comes on regardless of whether the knob is turned on or not....again....dunno what that really means. but the light doesnt go on or off with the knob. just constant on if 12v to middle spade. its probably screwed but it looks nice and original... i guess part of me just wanted to hear some old time crackly am coming out of it. even if i will never turn it on
Old 01-18-2015, 12:15 AM   #14
FirstOwner69
Here's a zoomed pic of the radio end. Looks like they are evenly spaced. I'd check, but I'm 2000 miles from the truck and my spare radios.
Old 01-18-2015, 12:22 AM   #15
freezmcnally
oh ok thats pretty clear...thanks.
Old 01-18-2015, 12:26 AM   #16
FirstOwner69
Just looked of a different picture I have on file from an old eBay listing. In that shot, it does appear the hot wire is spaced farther than the 2 speaker wires are spaced.
Old 01-18-2015, 12:35 AM   #17
FirstOwner69
This thread has some diagrams for radio installation. It clearly shows the power wire to the spade closest to the side of the radio.
http://67-72chevytrucks.com/vboard/s...d.php?t=518727
Old 01-18-2015, 12:36 AM   #18
freezmcnally
ok cool. thought maybe my radio was weird. well. it must be a dud
Old 01-18-2015, 12:38 AM   #19
FirstOwner69
See post 17.
Old 01-18-2015, 01:02 PM   #20
freezmcnally
See post 17.
awsome...thx...i missed that when i was looking at these on my phone.
very helpful
Old 01-18-2015, 01:08 PM   #21
freezmcnally
i see by this i am also missing the spacer and nuts that go on before the chrome spacer and knobs
