01-21-2015, 10:39 PM | #1 |
Top rear u bolt plate replacement?
Wondering where one can get a replacement of this piece not exactly sure what it is called. I got what I thought was the replacement from LMC put them on and they broke. Those where made of cast and called a rear axle spacer.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-22-2015, 12:12 AM | #2 |
Re: Top rear u bolt plate replacement?
I would talk to http://offroaddesign.com/index.htm they probably have better ones for you.
01-22-2015, 12:21 AM | #3 |
K I will check it out.
Thanks Nathan
01-22-2015, 02:43 AM | #4 |
Barns 4wd has some beefy stuff, I used their shock tabs. http://www.barnes4wd.com/Leaf-Spring...arts_c_12.html
Here's what happened to me with some Ranchos I had and tried to use, Junk! http://67-72chevytrucks.com/vboard/s...d.php?t=638867
White K20 |
