Old 01-26-2015, 11:13 PM   #1
72MARIO
72MARIO's Avatar
Aftermarket Engine crossmember ?
I am looking at converting my 68 longhorn frame to a 4wd. Plans were to build a Cummins Driveline but the long term cost comparison and simplicity of repair keeps going back to a gas truck. I need to be able to fix it quickly. The working season is short for reroofing here in Ontario so I can't wait 2 weeks for non stocked parts.
So what I have decided to build is a gas 4x4. I am looking for options on engine and transmission crossmembers. Are there any company's that custom make one ?
I am planning on building a big block with a 4L80 attached to a 205 case. I have been offered a 3/4 ton Dana 44 supppsto be a " military" Axel. Whatever that means.... Thicker tubing anyone have experience with them ?
The truck will be used for my roofing business I only will be using 4wd to crawl up steep driveways towing a 6000lb trailer .
Any help or input on what I should be using is appriciated. This it the body that will be used on the completed frame.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-26-2015, 11:28 PM   #2
72MARIO
72MARIO's Avatar
Re: Aftermarket Engine crossmember ?
This is the 468 parts truck. Going to donate its engine hydro boost brakes and rear sway bar. To bad it was not 4wd
2005 TAHOE DD
Old 01-27-2015, 04:31 AM   #3
andrewmp6
Only crossmember i know of is http://diy4x.com/cart/index.php?rout...&product_id=80 as far as a military dana 44 that's just made up stuff people believe.With a big block and weight you need to pull i would look more in to 1ton running gear for it.
andrewmp6 is offline   Reply With Quote
Old 01-28-2015, 07:18 PM   #4
Mr. 250r
Mr. 250r's Avatar
Diy4x as stated, ord and tna unfortunately your year is the problem nobody has a listed crossmember for the year diy4x starts at 69 you could call or email all 3 and ask them about it though.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
