Old 01-27-2015, 10:34 PM   #1
botsdots
How do I remove stud from RCD Classics shocks (with pictures)
Here are shocks in question.
Anyone know how to remove the factory stud? I can't figure it out.
botsdots is offline   Reply With Quote
Old 01-27-2015, 11:25 PM   #2
bdiamond
Re: How do I remove stud from RCD Classics shocks (with pictures)
I'd say grind that rivet and see what happens.
bdiamond is offline   Reply With Quote
Old 01-27-2015, 11:29 PM   #3
botsdots
Meh. Okay. I'm really looking for a way to mount these above the frame rail. Looks like Porterbuilt or Hotchkis have options. Though Hotchkis' product comes with shocks and I doubt they'll sell them separately.
How strong do those mounts need to be? I'm tempted to just cut some steel tube and use that. I don't weld, so cutting would be the limit.
Old 01-28-2015, 12:23 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I ran into this too. Luckily a good friend of mine worked at Bilstein and was able to remove these ends (they screw on) and put a set of standard ends on. He had special clamping blocks that held the shaft as he put them into a 12 ton press. Once the shaft was clamped to not rotate, he used a big wrench to remove the ends. Biggest thing is to not score the shafts.
I did this as I wanted to use the outer reinforcement brackets that CPP sells.
Here is what it looked like when done.
That said, I still have the old parts and could test out grinding the rivet off and seeing what is behind the washer, if you like.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-28-2015, 12:25 AM   #5
botsdots
Are you running part number 55-R033 ?
They just seem too long? maybe I'm crazy.
Old 01-28-2015, 12:32 AM   #6
chevy_mike
chevy_mike's Avatar
I would have to check. I bought these from CPP so it's whatever version they are selling. Bought them 2.5 years ago.
Edit: Looked at CPP site, yes that is the part number.
