Old 01-28-2015, 10:23 PM   #1
72MARIO
72MARIO's Avatar
GM Dana 60 drw to Dodge srw hub identify help !
I have a pair of what I think are 80's dodge srw front hubs I am looking at converting a GM drw Dana 60 front. I am hoping someone could help identify these hubs. They are stamped BUDD 102764. I would like to use them to convert the dually front to a single wheel Axel. I think it should work all I have is these hubs and rotors. I got them at a estate sale they were in original boxes just really wet.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-29-2015, 05:09 AM   #2
Jsfucttruck
Re: GM Dana 60 drw to Dodge srw hub identify help !
A brief Google search lead me to quad4x4. They recognized that casting number as a Dodge Dana 60 internal splined hub. Available on 89' and later models.
Look up the bearings and seals for a Chevy 60 and compare the part #'s to the dodge listings. If they are the same, try it.
Hope it helps, good luck.
Let us know what you find.
Jsfucttruck is offline   Reply With Quote
Old 01-29-2015, 07:35 PM   #3
b454rat
They are the same but the rotor is different, again it will work. I'm pretty sure Dodge and GM calipers/pads are the same. Dodge rotor is thinner than the GM rotor....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 01-31-2015, 12:34 AM   #4
Maxxd07
Maxxd07's Avatar
Also the D60 in my 89 dodge has only 1/2 studs in it. I believe the Chevys have 9/16 studs.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 02-01-2015, 04:11 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I ran the early 80s Dodge external drive hubs on my GM Dana 60, I used GM callers, rotors and bearings. The Dodge hubs did use 1/2" wheel studs but the GM 9/16" studs fit the Dodge hubs.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-01-2015, 08:30 PM   #6
72MARIO
72MARIO's Avatar
So I just need to find the manual locking hubs for a dodge that fit this hub ? The everything else is a bolt in ?
2005 TAHOE DD
Old 02-02-2015, 10:37 AM   #7
b454rat
If the Dodge uses the external hubs yes. If not, they GM, Ford and newer Dodge (89-93 roughly) uses the same lock outs.
Old 02-17-2015, 01:27 AM   #8
68post
Did you get this swap done ? I need to change-over my dually to srw front and rear also.
Looking for more info.
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 02-17-2015, 08:30 PM   #9
72MARIO
72MARIO's Avatar
No I haven't yet. Going to be a while honestly most likely next winter. But from everyone I talked to it sounds like it should work.
2005 TAHOE DD
Old 02-17-2015, 10:53 PM   #10
68post
OK , thanks. I'm digg'n for info - if I have anything to lend I'll be back to spill the beans !
Tim K.
