Old 01-29-2015, 12:01 AM   #1
Alex41
Ls2 GTO question
Ok...my head is hurting from all the research I've been doing here lately..lol. I just can't seem to find an answer to one question. I have an 81c10 and a newly acquired LS2/4L65E from an 05 GTO. I was unaware of the odd oil pan on this car until we pulled the engine out the other day. The oil filter is about in the #3 cylinder position under the car. I assume this will not jive with the truck's K member, is that right? I really hate to have to source another pan especially since I would like to keep everything as tucked up as possible.
Thanks for the help and look for a build thread soon. Alex.
Alex41 is offline   Reply With Quote
Old 01-29-2015, 12:40 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Ls2 GTO question
No way a front sump GTO pan is going to fit in a truck. Just get another pan, CTS-V or H2 Hummer or something and be done with it. The GTO pan will sell, I know 240sx swaps need them, so you can offset the cost of a new one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-29-2015, 10:20 AM   #3
1FUN64
1FUN64's Avatar
Just went through the oil pan research deal and came up with some good info. I need to start a thread about this but here is the quick and dirty.
Go to GMpartsdirect.com, put the following part numbers in the search and it will show pictures with dimensions and at the bottom it shows all the part numbers of the items to work with the pan, windage tray, pickup tube, etc... Also has application information for what they originally came on if you want to hit up the salvage yards.
12628771
12631828
12640748
12581209 Front sump (not what you are looking for) maybe what you have.
19212593 "swap kit" 8" rear sump, Summit.com will show all dimensions on this one.
302-2 Holley replacement pan, Summit for these dimensions also.
302-1 Holley also, Holley.com for these dimensions.
You can also search these part numbers on ebay for some products also. GMpartsdirect has some good pricing but shipping and handling is kind of expensive.
Good luck with the swap.
Kent
DRIVE IT HARD, DRIVE IT OFTEN!
Short video of Black Betty & a friends 48 Panhead done by my kid.
https://www.youtube.com/watch?v=8DlAdfwDQa8
1FUN64 is offline   Reply With Quote
Old 01-29-2015, 03:35 PM   #4
Alex41
Damn... I was worried about that.
Thanks for the info guys. I'll try to source an F body pan to keep the cost down.
Just to get a ball park idea, how much do the front sump pans normally go for ?
Old 01-29-2015, 03:46 PM   #5
1FUN64
1FUN64's Avatar
The 12581209 front sump pans on ebay are listed for almost $400. Some new, some used, may have more value with windage tray, pickup tube and everything together. Seems kind of high to me but who knows.
Maybe you can make some money on the swap.
Kent
Old 01-29-2015, 03:54 PM   #6
1FUN64
1FUN64's Avatar
This LS1tech link has a lot on oil pans.
http://ls1tech.com/forums/conversion...-oil-pans.html
Kent
Old 01-29-2015, 05:56 PM   #7
ls1nova71
ls1nova71's Avatar
F body pans are getting kind of hard to find and can also be pricey. If your truck isn't slammed on the ground, the GM muscle car pan should work and is the most reasonably priced. You get everything from pan, windage tray to dipstick for about $150. It may hang down below the crossmember a half inch or so depending on what mounts you use, but again, if you aren't slammed on the ground it should be fine. http://www.ebay.com/itm/Oil-Pan-Kit-...a9bd5a&vxp=mtr
On a side note, DO NOT forget to knock out the little plug in the block where the dipstick goes before you put the new oil pan on, or you will be pulling the pan again. The plug needs to be knocked out from the bottom.
Old 01-29-2015, 06:01 PM   #8
Alex41
Man...you guys are on top of this. Thanks a bunch.
Old 01-30-2015, 09:40 PM   #9
BP Automotive
I cant help you a lot with the hard parts, but we are one of the very few companies that build the 05-06 E40 harnesses for your application. And we usually have them in stock ready to roll.
We can help with the electronics on your swap if you run into any wiring or electronics questions feel free to give us a call. 270-805-1777
BP Automotive is offline   Reply With Quote
