Old 01-31-2015, 07:52 PM   #1
BlueBullet
BlueBullet's Avatar
Parking Brake Cable Question
When installing a 2" lift does anyone know if the parking brake cables need to be longer then factory. I got new ones and they seem to fit tight.
Nathan
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 02-01-2015, 09:32 PM   #2
Mike C
Mike C's Avatar
Re: Parking Brake Cable Question
My Jimmy has 4" lift and stock parking brake cables. I switched to a semi-float 14 bolt moved back 1" by re-drilling perches and I used my original parking brake cables again. So the original cables should be plenty long enough for a 2" lift.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-01-2015, 09:47 PM   #3
redbaron
redbaron's Avatar
On our K10 with 4" lift and center pin moved back 1", we had to use 3" longer park brake cables from rear end to frame. Used the stock intermediate and front cables.
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 02-01-2015, 09:48 PM   #4
BlueBullet
BlueBullet's Avatar
I must be looking at it wrong or possibly routing it incorrectly. Thanks for your input.
1967 Pontiac GTO
Old 02-01-2015, 09:52 PM   #5
BlueBullet
BlueBullet's Avatar
Thanks for your input and your truck is looking real good. Can't wait to see it finished
Nathan
1967 Pontiac GTO
