Old 03-19-2002, 10:03 PM   #1
sigurd
sigurd's Avatar
Post Aluminum or Steel driveshafts ( Pros and Cons )
What do you guys and gals think? I have the option to have my rear driveshaft made out of steel or aluminum.
72 SWB K10
San Diego CA
72 SWB K10
San Diego CA
sigurd is offline   Reply With Quote
Old 03-20-2002, 01:53 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I'm not a big fan of alluminum, myself, I've never tried one, but I would think the rock chips would eventually eat the thing up and weaken it. Lightweight is nice, but you just can't beat old school.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-20-2002, 04:05 AM   #3
Alexis
Member since 2000
Alexis's Avatar
Post
it mainly wieght and brute streght you give up with alunium, lots of the newer chevys run aluminuim but there huge SOB. wouldn't trust it off roading, give you the sence it will snap. i dont know why poeple say it stronger, we get more bust alum wheels then steel, but alum does look alot cooler
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 03-20-2002, 08:29 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Well, it's not a truck, but when GM replaced the driveshaft of my dad's 1994 Camaro Z28 (recall; most of the 6-speed cars, his included, shipped with unbalanced driveshafts) they used the 1LE aluminum driveshaft as a standard replacement. Not a single problem with the driveshaft since, and I know it made doing the clutch recently at least that much easier, heh. It's a good 7 years old and it looks perfectly fine to me, no problems with rock chips or anything.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-20-2002, 08:51 PM   #5
Reumster
L.E.D. Freak
Reumster's Avatar
Post
Absolutely not true, any good quality Aluminum drive shaft from a high performance maker will be stronger and lighter.
And if you really want to get crazy go with Carbon Fiber driveline, Better that both.
1972 2wd Blazer, 350/700R4/3:73 posi/NOS. Power is nothing without control!
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-20-2002, 08:57 PM   #6
jmanz69
Careful, they attack...
jmanz69's Avatar
Post
Aluminum would be stronger and lighter, but maybe not as practical. Probably cost more. But the physics are there for it to be stronger. Since it's way lighter it could be made thicker which would actually give it more strength than a steel one. Just my 2 cents
jmanz69 is offline   Reply With Quote
Old 03-20-2002, 08:58 PM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
Exclamation
Correct!
(406)675-8082
