Old 02-16-2015, 11:17 AM   #1
72 k10
experience w dual transfercases
I was thinking a dual transfer on my 72 chevy, in the Toyota world they reportedly workwell giving you very low gearing while still maintaining good hiway hiway gearing. So I was wondering what experience guys have had pro and coins. Thanks
72 k10 is offline   Reply With Quote
Old 02-16-2015, 11:29 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: experience w dual transfercases
Check out these guys http://offroaddesign.com/catalog/doubler.htm uses components from the NP203 with a NP205.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-16-2015, 02:57 PM   #3
72 k10
Yea that's the one I was looking at. I have not ever been around one or talked to anybody that has one to see how well they liked it.
Old 02-16-2015, 06:06 PM   #4
b454rat
When they are both in high you wont notice a difference. But in double low, then you will see the difference
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 02-16-2015, 07:25 PM   #5
Mike C
Mike C's Avatar
Doubler's are awesome if you have enough wheelbase, and the ORD is the standard. Mostly there is no need for a 4:1 low range, but if you need it you may REALLY need it. But the great thing is you can still use the 2:1 standard low range.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-17-2015, 12:31 AM   #6
andrewmp6
The other option is running a under drive box like off road design has one or http://www.northwestfab.com/NWF-Blac...drive_c_7.html http://www.high-impact.net/transmiss...e_brochure.htm
andrewmp6 is offline   Reply With Quote
Old 02-17-2015, 08:51 AM   #7
doubleclucker
doubleclucker's Avatar
Heres is my link I drive the truck everyday; it has its advantages in alot of offroad situations. If you have any swap questions ;just ask.
http://67-72chevytrucks.com/vboard/s...d.php?t=611566
100:1 low gear!
doubleclucker is offline   Reply With Quote
Old 02-17-2015, 09:39 AM   #8
jjzepplin
jjzepplin's Avatar
Had my ORD for over ten years. Went thru the Rubicon several times with no hitches. Drove it to Fl. From Cali no issues. Still working great. A true stump puller for sure. And Boat launching is just fantastic. Coupled to the 700r4 it is unstoppable.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-17-2015, 10:53 PM   #9
DWilbur
I went the extreme installing Advanced adapters 4 speed T-case. they do cost more than NP203 with NP205. but I get 10 to 1 low gear and over drive with NV4500 5th gear.
DWilbur is offline   Reply With Quote
Old 02-18-2015, 03:23 AM   #10
andrewmp6
Just remember it does take a little fab for a the t case crossmembers and both driveshafts will change in length.If your a hardcore off roader i would go for it,If your more a middle ground off roader a twin stick np205 with the 4to1 gear set will work great too.
Old 02-18-2015, 10:07 PM   #11
obijuan
unfortunately the 4:1 gears for a 205 arent out there. just a 3:1 lomax set which is a little over budget for most people and might not be enough for other people.
http://youtu.be/jG4Ki0j8-Lk
this is first gear and 4:1. the power and torque are awesome and the engine wont stall no matter how nose high i get. for the most part i try and idle obstacles and goose it if i need to.
i have 4.56 gears and 42 inch tires. i can put it in first with 6.5:1 and 4:1 and walk faster.
obijuan is offline   Reply With Quote
Old 03-01-2015, 03:03 AM   #12
72 k10
Obujan that looks like a lot of fun. I think the duals is the way to go as far as any fab and welding that's just more fun for me. Thanks for all of your replies and experience
Old 03-01-2015, 07:39 AM   #13
snj8198
snj8198's Avatar
How did I miss this thread?!
I've had 2 203 range boxes fall into my lap at no cost, but timing didn't fall right for the doubler conversion so i ignorantly scrapped em. After playing on the narrow logging trails I find twin stick and ground rails a necessity next to the compound low range.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
