Old 02-26-2015, 07:40 PM   #1
HuntinNut
Gettin Parts Togather For My 6.0 Swap. Have Questions
Finally got my 2002 LQ4 w/317 heads and have a few questions about parts before I start buying.
1. I'm looking for a LS1/LS6 style intake. If I buy a LS1 or LS Qualifier Intake do I just buy a fuel rail off ebay and use my injectors from my truck intake? Also I'm switching over to DBC so do I just buy the throttle body to switch it over?
2. My motor came without a harness. Can I use a harness from any 4.8/5.3 or 6.0 since I'm sending it off for stand alone anyway?
3. Same question for the ECM. Since Im sending it off does it have to be a 6.0 or will any LS ECM work?
4. What about the knock sensors, can I just swap to a flat valley pan without provisions to get rid of them?
I'm sure Ill have tons more questions as I go along and try to do my research, but I'm chomping at the bits to order parts and just don't want to make a mistake..
HuntinNut is offline   Reply With Quote
Old 02-27-2015, 09:24 AM   #2
solidaxel
solidaxel's Avatar
Re: Gettin Parts Togather For My 6.0 Swap. Have Questions
Watching this one !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-27-2015, 10:41 AM   #3
chuckmc8
It's alsways something.....
chuckmc8's Avatar
My Opinion:
Best strategy here is to ask whoever you plan to do the harness mod and PCM tuning.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 02-27-2015, 11:10 PM   #4
Dustytrix
The injectors will not work get some for the ls1/6 intake. The harness can be made to work but its gona cost more since it was dbc, and you want dbw, so all those wires and connector will have to be added. And injector connectors will need to be changed if harness came from truck. Also you need tac and petal assembly.
Get a harness from the setup you want to run, saves lots of money. Or order a standalone that you need.
Dustytrix is offline   Reply With Quote
Old 02-27-2015, 11:26 PM   #5
H20cooled
I bought a stand alone harness from BP Automotive, it was less than buying a GM harness and having it redone and its a much nicer setup that a redone one. If you call BP Automotive they can help you out a lot and answer questions, plus they are a sponsor on this site.
Rich
H20cooled is offline   Reply With Quote
Old 02-28-2015, 12:31 AM   #6
HuntinNut
I'm wanting DBC, not the DBW that I have now. That's why I wanted to know about the harness since all the DBW stuff wouldn't be used anyway.
Old 03-01-2015, 08:14 PM   #7
Dustytrix
Sorry misread the post, either harness should work then. Delete what you dont need,
