Old 03-07-2015, 08:04 PM   #1
AntiGov
AntiGov's Avatar
87 chevy lift question. ..?????
Currently as I type this installing a tuff country 3" lift on my sons truck. Everyone says I don't need a steering arm unless 4" or greater. I like to make things correct as possible. I can't seem to find a 3" arm but I do have a 4" arm lying around somewhere I think I can use. Sure it's 1" over correction but I think it's better than 3"" under corrected . Any thoughts ? Also where is a good place to order extended brake lines ? I didn't get these ahead of time cause I was told my local napa carried them, they of course don't . Any info appreciated.
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-07-2015, 08:47 PM   #2
b454rat
Re: 87 chevy lift question. ..?????
You dont' need the arm for less than 4". Put the lift on with stock arm, see how it sits after awhile. If the draglink isn't level, or slightly lower at axle end, then you could get a spacer between the stock arm and knuckle. Check out offroaddesign.com, they have both I believe....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-07-2015, 08:53 PM   #3
dieseldawg142
dieseldawg142's Avatar
yup, x2^^^ should be fine. got my skyjacker brake lines from summit
when i saw your name & lift in the same sentence thought that fine crew of yours was going up....
dieseldawg142 is offline   Reply With Quote
Old 03-07-2015, 09:18 PM   #4
Myers horsepower
Myers horsepower's Avatar
I have the Superlift 3.5" lift on my 3500 and didn't need new brake cables. There is plenty of length.
Your son have a Nice looking truck!
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60.
1972 CST K5 350/th350/12blt,eaton posi/D44
1970 K10 SWB
1970 K20 350/th350
Myers horsepower is offline   Reply With Quote
Old 03-08-2015, 12:54 AM   #5
72MARIO
72MARIO's Avatar
Thia is a quote from off road design
We ran the stock steering setup for a couple months and while its function was fine, it had a small bit of bumpsteer so we added a 2" drop pitman arm and now the truck drives as good or better than it did to start with. Part # is SKYCA50 for $95.00.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-08-2015, 12:54 AM   #6
72MARIO
72MARIO's Avatar
http://offroaddesign.com/action/burly-burb.htm
2005 TAHOE DD
Old 03-08-2015, 09:29 AM   #7
I'd have to look at the lift arm, but are they a full 4" more offset than stock, or closer to 3"? Although they say you don't "have to", I get what you're thinking. If the steering arm is closer to 3" offset over stock then it should result in keeping right about the stock geometry, which is good. The same lift arm is used for 4 and 6" and I don't know of any taller for bigger lifts. There is stock and there is a range that will work over and under that angle. If you lift 2" and keep the stock arm as recommended you have more angle than using a lift arm with 3" lift. For me using a spacer is a no go and I'm not too fond of the bent drag links. Drag links pivot as well as turn and go up and down. As they pivot (ever so little, I know) it changes it's geometry ever so little. Picture a hand crank. As the suspension cycles, wheels turn, and that part pivots I see changes in geometry that won't occur with a straight part, as factory designed. if nothing else, I'd think the ends could wear faster, especially if not lubed often enough
Old 03-09-2015, 08:50 PM   #8
DWilbur
A drop drag link would work for 3" lift. Skyjacker makes one. ORD caries them.
DWilbur is offline   Reply With Quote
Old 03-09-2015, 10:27 PM   #9
AntiGov
AntiGov's Avatar
Went with the 4" arm guess I'll see how it works .if no good I will try that 3" drop
Old 03-09-2015, 10:32 PM   #10
AntiGov
AntiGov's Avatar
Still need extended brake hoses and a new steering stabilizer
Old 03-10-2015, 03:02 AM   #11
DWilbur
The lift kits I have installed come with a break line brackets to lower the front break lines to the below the frame so you can use the stock flex lines.
Old 03-10-2015, 11:02 AM   #12
AntiGov
AntiGov's Avatar
This kit did come with some flimsy metal brackets to relocate under frame but I just couldn't bring myself to use them ....I like the stock location and will just have to spend the $ 92 for new ones
Old 03-10-2015, 07:04 PM   #13
dieseldawg142
good choice
them brackets are flimsy, & whats a few bucks for your son's safety. new lines will most likely improve the feel of the brakes as well.
Old 03-11-2015, 12:33 AM   #14
AntiGov
AntiGov's Avatar
Originally Posted by dieseldawg142 View Post
good choice
Yeah I got skyjacker ones also. They are for up to 4" so should be about perfect. Rough country had some for cheap like $ 35 for the pair but they were good up to 6" lift .... so 3 inches longer than they should be IMO for a three inch lift
