03-10-2015, 11:56 AM | #1 |
Post Whore
305E v6 performance?
So....If any of you know me wel. () You'll know that I'm the type that likes to take the stock engine and punch it out for power. Like my 292 I'm sure some of ya'all have seen...if not, check out my build thread..But anyway...to the point. Just bought a 64 GMC and it has the 305E v6. Heard of some upgrades that can be done..500 2 barrel holley, hei, bigger dual exhaust...but that ain't close enough for me. No, I'm thinking compression pistons...Arias will make a custom set...little more lift on the cam, and if a set of 401 magnum heads will bolt on, then a set of those with the intake machined to fit a 4 barrel. I've been told the 351 heads will bolt on so, I'm thinking a set of 351 magnum heads for the larger ports and I think bigger valves..if not..well..changing that to. lol So anyhow...has anyone done this? Yes I know about the GMC guy and that forum so I don't need those links..I've looked there and only saw some stuff about the intake being machined for a 4 barrel, and Of Course cause I'm not a member I couldn't see the pictures. But anyhow...I guess my main question is..has anyone done a head swap? Or done the 4 barrel? Also saw a guy doing a turbo on his. Staying close to that one. lol So if any of you have done the 2 barrel swap I'm am interested as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-10-2015, 07:20 PM | #2 |
Re: 305E v6 performance?
Your biggest issue is that the rotating assembly weighs a ton in those engines. Rpm makes horsepower and you just cant spin those engines. I guess if you have a bottomless pit of a bank account you could have a crank,rods and pistons made but it will accomplish nothing other than to claim you did something different. It seems people get so caught up in the quest to be different that they lose track of being sensible especially when it comes to money spent vs gains made. The 305 and 351 v6 was never intended to be anything but a work horse running at near constant rpm.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-10-2015, 09:28 PM | #3 | |
Post Whore
03-10-2015, 09:38 PM | #4 |
All I have done to my 305 is the 500 holley dual exhaust and electronic ignition, just those three made a big difference.
I have read threads where one was converted to a TBI, one added a turbo, one used connecting rods out of a 426 hemi with custom pistons and the rumor was it screamed. Yes magnum heads will bolt on, the magnum intake can be machine for a 4 barrel. A lot of threads on 401 and 478 being built and used for pick up. I have a 401M stashed in the corner of maybe one day I'll get to it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-11-2015, 10:27 AM | #5 | |
Post Whore
03-11-2015, 10:41 PM | #6 |
That's the problem...you can't make HP without RPM. HP is simply a by product of the torque produced at a certain rpm. However peak torque is not directly related to RPM so you shouldn't have much problem getting more tq.
71 K20 64 GMC mud truck |
03-11-2015, 11:32 PM | #7 |
Post Whore
I hear ya, though more hp can be accomplished by increased compression, larger bore, more air flow, induction, all those still are major increases in torque more than anything.
03-12-2015, 07:59 AM | #8 |
GMC V6 is just plain cool and it will run all day long. I love mine and would not swap it out.
03-13-2015, 11:50 AM | #9 |
Post Whore
I agree...love mine to. Its another buzzin half dozen. lol
03-13-2015, 10:35 PM | #10 |
I copied and pasted this from somewhere; maybe this forum or another, I'm not sure. It does have some specifics about performance changes.
Heres a little about these motors I learedt back in the mid 80's. My grand father gave me his 1965 GMC 1t 4x4 that came with the gas 351c v6. I rembered from a kid that this old truck would out pull anthing and never broke down. The old 351 was getting tired with about 200k on it so i decided to rebuild it and of coarse hop it up. So I started looking into performance imfo on these motors. That put me in contact with Babe Erson. He told me about the gas 478M motor and how with some work the big 478m v6 will easily make more tork and hp than a mildly built 454bbc. So I bougth a 478m motor from the junk yard and went to work per Babe's rec's. The first thing was to throw away the stock 4 ring pistons and masive rods that weight about the same as a complete hemi motor. I had a crank grinder turn the rod journals down to a much smaller size to fit a 426 hemi rod. I had BRC make some new lighter 3 ring pistons that also raised the cr up from 6.5 to 9.0. Engine dynamitics lightened the crankshaft alot and rebalanced every thing for me. Babe made me a special cam and all the vale train parts. I ported the heads and polished the combustion chambers myself. I also made a sheetmetal cross ram intake with 1 850cfm Q Jet carb and a set of home made 1 3/4" headers. Once I got all the tuning done on this motor it was one tork animal that would rev easily to 5.5k. It broke the transfer case right away so I put in a beffier transfer case out of a newer ford truck I think then I blow the old gmc rear end so I upgraded it to a dana 70 with posi. I also upgraded the old truck 4 speed to a newer 5 speed that could be shifted much faster. I had put big 38" tires on this truck and could smoke them in 2nd gear. It did not do to bad on fuel also at about 12 mpg fully loaded with a 10ft camper and pulling a 30ft enclosed trailer running about 65mph. I wish I know where this truck (James) is today as I would try to get him back
MusicMan70 1961 GMC Suburban |
03-14-2015, 10:55 AM | #11 |
Post Whore
Thanks for the reply Music Man! Yeah, I'm liking what that guy did. Man that's sweet.
03-15-2015, 02:16 PM | #12 |
I think different is cool if you can afford it.
I thought about rebuilding my truck's 250 six and scrapping the integral head & intake manifold, or maybe going to a 292. But after looking into parts prices, it would have cost more than rebuilding a junkyard 350. And the 350 would make 25%-50% more torque and horsepower. Of course, now the 350 project is costing a lot more than it should have! If I could turn the clock back 6 months, I would at least tear down the 250 to determine if the short block was rebuildable. But had I gone that route, the 2.73 axle would have to go. Paired with the 250 six, it's like asking grandma to move a refrigerator.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
03-16-2015, 10:25 PM | #13 | |
Post Whore
03-17-2015, 09:42 PM | #14 | |
03-17-2015, 09:56 PM | #15 |
Post Whore
Well imop a project isn't just about "best bang for the buck" its about what you want to do and how you want it. I'm not against SBC's...believe me I was going to do a swap before I found out of all the options available for the I6. What I rag about is people telling other people that building an inline 6 is a waist of money. THAT's what gets me upset (1) because its not true. (2) cause there are alot of people who go the 350 route because of it. And its a darn shame when I go to car shows and see nothing but SBC's in almost 80% of the chevy cars and trucks....The other 15% being BBC's(nice change) and the 5% being stock or hopped up inlines(keeps my eyes looking at that car or truck the longest). But everyone has and is entitled to their opinion and I'm stating mine is all. If I was one of those people who asked this forum about building the 292 I probably would have a 350 in there today and be staring at my 292 saying to myself.."Man, would have been nice to see that thing hopped up." But I decided to learn for myself instead of asking other people's opinions and I'm a happy man today because of it. And not to say asking someone's opinion is a bad thing. I've been help a TON and a half by this forum. But finding things out for yerself ain't a bad thing either.
03-18-2015, 11:28 AM | #16 | |
Seriously, I do know what you mean about being told anything smaller than a 350 is a waste of money. Can't tell you how many times I ran into that attitude when building a 327 for my 55 Chevy sedan. And guys building a 265 or 283 really get beat up. Several years ago, I gave away a perfectly good 307. It would have made a great budget engine for my truck, and would have been different, at least internally.
03-18-2015, 11:36 AM | #17 | |
Post Whore
03-18-2015, 12:20 PM | #18 |
Love the "one off" projects that "dare to be different". Stick to your guns, enjoy yourself, and remember this one important thing:
It's YOUR truck and YOUR happiness. The best, most important thing you can get in life is happiness, and it comes in all ideals, shapes, sizes and colors. |
03-18-2015, 01:29 PM | #19 | |
Post Whore
03-19-2015, 11:59 AM | #20 |
And it's not like a big V-6 engine will be a wimp, like a smaller inline six. (OK, a 292 can be pretty strong, too!)
03-19-2015, 12:03 PM | #21 |
Post Whore
Know a guy with a hopped up 250...he leaves 350's in the dust all that time. lol No his isn't turbo charged! Ya gotta admit though....the 350/260 is perrty wimpy. Driven a few and they are as slow as my stock 292...LITERALLY. The 350/290 isn't so bad but is a gas guzzler for the power it makes.
03-19-2015, 04:18 PM | #22 |
I only own small blocks: 350, 355, 400 with automatics: T350, T400 and a 700R4.
So basically I'm jealous LOL. I love a "one off" project, and my dream truck would be a 351 V6 TOTT 4WD short-bed step-side. Kinda like to have a big block in the herd, I suppose the SB400 will have to suffice for now. If I had a V6, I would be an old dog trying to learn new tricks, oops, I mean trucks. |
03-19-2015, 07:02 PM | #23 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Those valve covers gotta be good for 100 extra horsepower!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
03-19-2015, 07:15 PM | #24 |
03-20-2015, 11:13 AM | #25 |
Post Whore
Actually the story goes that the plaid valve covers were the same treatment at painting an engine ford blue.
