Old 03-15-2015, 10:59 AM   #1
MyDad'sTruck
Drums or Discs on 68 4x4x
Am in a position to possibly swap front end to gain disc brakes, but reluctant to do so. Ive driven the truck since i was 15 and am used to the current brakes. Would rather put money into a lift kit and the t-case.
Also I would miss using the original hubs, etc. What do y'all think?
MyDad'sTruck is offline   Reply With Quote
Old 03-15-2015, 11:11 AM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Drums or Discs on 68 4x4x
I think it's one of the best upgrades you can do and it would come first on my list. Besides better braking you get a much closer turning radius and better parts availability. You can find all different kinds of locking hubs if your wanting something period correct they're still out there.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-15-2015, 11:16 AM   #3
'63GENIII
'63GENIII's Avatar
When I swapped to disc on the 63, the difference was night and day. Not saying that a properly set up drum won't work great, just saying that with a lift and bigger tires that a front disc axle will probably work a little better. I've been guilty many times of making it faster, bigger and able to do more first and addressing stopping last. I try to address stopping first now as my heart can't take the pucker factor when it won't stop as planned.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-15-2015, 11:17 AM   #4
'63GENIII
'63GENIII's Avatar
X2 on the turning radius also!
Chris
'63 k15 long step
Old 03-16-2015, 07:19 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Just go with a 73 and up axle since they have slightly larger axle u-joints. The late 80's axles have slightly larger axles/more splines, not sure of the year cut off though.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-16-2015, 09:27 PM   #6
MyDad'sTruck
Will know tomorrow if my shop has the axle we want; thinks he does. I'm going for it if its in the garage.
Old 03-21-2015, 05:03 PM   #7
MyDad'sTruck
Truck will have new front end this week! Cant wait.
