Old 03-30-2015, 09:47 AM   #1
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
np205 short vs long 32 spline input
Does anyone know where I can find a long version? I have a short version but I'm getting a custom adapter made for the nv4500 and figure 8 np205 and I need the other shaft. The short 32 seems to be more desirable of the two but I'm still having trouble finding the long 32 spline input. Thanks in advance!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-30-2015, 07:56 PM   #2
ryanroo
ryanroo's Avatar
Re: np205 short vs long 32 spline input
off road design.
they will get about anything you need for a 205. anyone doing a nv4500 swap that is not using the spacer would have one too i would think.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-31-2015, 12:21 AM   #3
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I'll look again and see what they have available. Thanks
Tony
Old 03-31-2015, 08:07 AM   #4
ryanroo
ryanroo's Avatar
no problem. you may call. they are very helpful and may not list it as most people are going the other direction.
72 K20 12v build
Old 03-31-2015, 02:28 PM   #5
obijuan
That is not a reproduced part so if they have it, it will be a used one. Hit or miss on the long gears. I'll buy your short gear if it comes to it.
The long gears come up on pirate4x4 from time to time.
why the custom adapter? Have you seen this? You can use your tcase with the short gear and this plate All with the stock 4x4 trams adapter.
http://www.northwestfab.com/GM-NP205...pter_p_18.html
obijuan is offline   Reply With Quote
