Old 04-02-2015, 07:55 PM   #1
MyDad'sTruck
new lift question ? Skyjackers.
Will new springs settle at all after installation? Front is about 1" higher than rear, Rear is old leafs with block, front is new Skyjacker leafs. Love it otherwise!
Next will be cab mounts. Would think that would make it even higher up front.
MyDad'sTruck is offline   Reply With Quote
Old 04-02-2015, 08:10 PM   #2
b454rat
Re: new lift question ? Skyjackers.
They should settle over time...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 04-04-2015, 10:42 AM   #3
70'
70''s Avatar
They should settle, but it may take awhile. A lot of times a guy will slip an add a leaf into the rear to balance things out from the get go. Once the front settles you can always pull it right back out pretty painlessly. As with all things, there is a trade of for everything and in this case the add a leaf will make the rear ride just a bit stiffer.
70' is offline   Reply With Quote
Old 04-16-2015, 04:49 AM   #4
eager_adventurer
Where did you buy your lift kit? I was supposed to buy a Skyjacker too but ended up buying a ReadyLift Truck Leveling kit from 4wheelonline.
eager_adventurer is offline   Reply With Quote
