Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-05-2015, 03:02 PM   #1
sunk99
sunk99's Avatar
#rojok5blazer (bagged red K5 Blazer) 2wd project
Hello everyone, back in November I sold my suburban wit the intentions to start flipping vehicles on the side. I had also made up my mind that if I found something special that I would possibly build another project. Well I came across this blazer and made it mine so there goes the idea off flipping anything very quickly. I was excited to get the project home to see if I made a good purchase or not.I have not had very good luck buying vehicles sight unseen in the past and this one ended up being no different.
Scott
sunk99 is offline   Reply With Quote
Old 04-05-2015, 03:22 PM   #2
sunk99
sunk99's Avatar
Re: #rojok5blazer (red K5 Blazer) project
The engine was supposed to be a fresh built good running 427 BBC but upon inspection when I ran the numbers ended up being a mid 70s 454 with 72 402 heads that would barely run. I contacted the seller and tried to get him to make it right by refunding some money or taking the blazer back but had no luck with that so all I could do is try to make lemonade from lemons so here we are. I traced the #'s on it and ended up finding out that it was originally a government vehicle painted beige and had a 6 cyl. engine, camper mirrors, posi track rear end, and utility buckets.
Scott
Old 04-05-2015, 03:42 PM   #3
sunk99
sunk99's Avatar
I intended on selling the big block to fund an LS swap but after finding out that the engine wasn't what it was supposed to be I'm trying to see if its worth using or just going ahead with the plan an installing a LS based engine. Oh I forgot to mention that it has a truck 5 speed from I'm guessing a early to mid 90's Chevy. I started the transformation by installing a basic manual air ride system that Boris (way2low2) help me put together for it.
Scott
Old 04-05-2015, 09:15 PM   #4
sunk99
sunk99's Avatar
More pics using ridetech lower front control arms,mcgaughy's dropped spindles,track bar,and c-notch,2" lowering blocks,bags,and ridetech rq shocks.
Scott
Old 04-05-2015, 09:32 PM   #5
sunk99
sunk99's Avatar
More pics
Scott
Old 04-05-2015, 09:47 PM   #6
sunk99
sunk99's Avatar
The wheels and tires are wheel vintiques 15x6 15x8 with 215/70-15 and 275/60-15 tires
Scott
Old 04-05-2015, 10:10 PM   #7
sunk99
sunk99's Avatar
This week I received the 3 core champion radiator with shroud and dual 14" fans, Dakota digital VHX gauges from laid back recreations, some precision weatherstripping and some things from LMC that I couldn't find anywhere else.
Scott
Old 04-21-2015, 02:24 PM   #8
smbrouss70
smbrouss70's Avatar
I'm on board! Can't wait to see how this one turns out, I loved your Burb.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-27-2015, 02:38 PM   #9
smbrouss70
smbrouss70's Avatar
What size wheels & tires did you put on your Blazer?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 08-27-2015, 10:12 PM   #10
sunk99
sunk99's Avatar
Wheels vintique 15X6 215/70-15 and 15X8 275/60-15 purchased wheels from summit racing.
Scott
Last edited by sunk99; 09-14-2015 at 07:38 AM. Reason: Entered wrong rear wheel size
Old 08-27-2015, 10:37 PM   #11
sammygroundzero
Building a 72 k5 aswell.
Nice build
sammygroundzero is offline   Reply With Quote
Old 09-13-2015, 03:49 AM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
Dig it! Simple and clean
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
