need to know the model of this truck
Hi everybody,
I am 3D modeling a frame truck but I haven't found any info about the model on it. I have been looking on the internet and the dimensions and shape are very similar to the 1973 - 1980 Chevy / GMC pickup truck frame on this link: http://www.chuckschevytruckpages.com/framespecs.html But I'm still not sure if it is one of this or not. I'm attaching some photos below. Thank you in advance ![]() |
Re: need to know the model of this truck
With that rear, looks to be 88-up-ish OBS.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
The frame appears to be a 81-86 C30 or 87-89 R30 regular cab. Both should have a similar frame.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
thank you guys!!
If that rear end is a 14 bolt its a 88-98 truck.
It is a 14 bolt, but the front suspension "bolts" to the frame. 88-up do not, the spring pockets are molded as well.
