Old 04-10-2015, 07:58 PM   #1
GMJimmy
E Rod and a 4L65E
I'm planning on putting a connect and cruise setup (LS3 with a 4L65e) in my 70 shortbox stepside and I'm looking for some suggestions for the right rear gear ratio to use. The truck with 29.6" tires has a 3.08 in it now which will rev at 1704 rpm at 70 mph. 3.73's will rev at 2085 so I'm thinking maybe 3.55's may be better at 1964 rpm. Is anybody using the 4L65 or anything with a .70 (.696) OD and similar rear gear ratio that can tell me how they like it?
Suggestions appreciated.
Jim
GMJimmy is offline   Reply With Quote
Old 04-10-2015, 08:03 PM   #2
SactoJim
SactoJim's Avatar
Re: E Rod and a 4L65E
I think the general consensus is 3.73's are the best choice for auto 4 speed overdrives. 700R4 in mine with 3.73's.....works great!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 04-10-2015, 08:07 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
3.42 for all my 700R4's.
Good take off and great on the highway.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 04-10-2015, 08:23 PM   #4
GMJimmy
Thanks for the replies. 3.42's will get me to 1892 rpm at 70. What size tires are you guys running?
Old 04-10-2015, 08:25 PM   #5
donandal
I have that erod /4l65E in my truck...just got it in December.
the documentation with it recommended 3:42 with about a 29 inch
tall tire as I recall
donandal is offline   Reply With Quote
Old 04-10-2015, 08:32 PM   #6
68c10airstream
68c10airstream's Avatar
I just finished going to 18" wheels and a 28.2 diameter tire from a 26.5 diameter running through the same 3.08 ratio with a 5.3/4l65e and suspected a reduction in low end take off, and was correct. Rear end change/ratio change in the future and will be going to at least 3.50 or higher.
68c10airstream is offline   Reply With Quote
Old 04-10-2015, 08:45 PM   #7
GMJimmy
Thanks for the replies! I think I'll check out the GM documentation before I decide. I had a 2010 Corvette with a 26.7 tire and a 3.42 rear gear and in 6th with a .50 OD I was revving about 1509 rpm. A little sluggish but 6th was a fuel economy gear. 30 mpg with the LS3. I wonder if rpm that low would work in my C10?
Old 04-10-2015, 09:07 PM   #8
69 GMC Daily Driver
69 GMC Daily Driver's Avatar
Jim
Jim,
My LS6 and 4L65E are running 3.73 (w/posi.) It absolutely runs like a champ.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
70 GMC Serria Grande Short
70 Chevy C/10 Short LS Powered
72 Jeep J2000 4X4
86 El Camino (22k original miles)
69 GMC Daily Driver is offline   Reply With Quote
Old 04-10-2015, 09:10 PM   #9
Heavymetl
I've got a 3.25 9" with a 4L80E.
Granted, I just got the truck driving yesterday, but the 3.25 seems too tall for anything other than highway driving. I don't think you'd be dissapointed with 3.73's.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 04-10-2015, 09:17 PM   #10
CarterD2015
CarterD2015's Avatar
Depends on the type of driving that you are most likely going to be doing. I chose 3.73s because I drive mostly in town and I'm not going to be doing much highway driving.
CarterD2015 is offline   Reply With Quote
Old 04-10-2015, 09:38 PM   #11
GMJimmy
I'm planning on both highway and city. Around town and those long road trips to the Goodguy's shows. I have a 2006 Silverado with 3.73's and a 6.0 Vortec Max and a 4L65E and it runs about 2000 rpm at 70 and has a 30" tire. The C10 is a lot lighter so I should be ok with something like 3.55 to 3.73. Thanks everybody for you suggestions! Really helps the decision.
Jim
Old 04-12-2015, 10:02 PM   #12
HSRACER
HSRACER's Avatar
I have both a 3.73 and a 3.42 ratio rear end with the overdrive trans. I like the 3.73 but the 3.42 is the perfect combination of acceleration and mileage. If building from scratch I would always do the 3.42 ratio.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
