04-13-2015, 12:19 PM | #1 |
Bolt in replacement headers
Hi!
First time posting, but I have been lurking for about a year. This is my 1972 C10 350 Anyway my question is, are there any bolt in header replacements for the short stock manifolds? I dont have any equipment to perform anything than a bolt in replacement. All the local shops are asking at least $200. |
04-13-2015, 12:43 PM | #2 |
laying low
Re: Bolt in replacement headers
First off. Welcome to the board. Good looking truck. We dont see many here with flatbeds. Its cool. So you are wanting to replace some headers with new headers or replace stock rams horn manifolds with? Either way you will still a muffler shop to hook them up.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 04-13-2015 at 12:49 PM. |
04-13-2015, 12:59 PM | #3 |
I don't really see any benefit to replacing the stock exhaust manifolds with equal length headers. Headers are advantageous in the upper rpms. If you are truly budget minded and have to have headers, the good ones aren't cheap, and the cheap ones have thin flanges that will have you spending more time under the hood, than in the drivers seat. The only reason i bring that up is you mentioned $200 from a shop, and that isn't a bad price. what are your reasons for wanting headers if you don't mind me asking?
04-13-2015, 01:32 PM | #4 |
Dont forget to unhook that chain hanging under the front bumper!
good looking truck
1967custom |
04-13-2015, 03:41 PM | #5 | |||
I have ram horn manifolds currently. |
04-13-2015, 04:03 PM | #6 |
You're far better off putting glass packs, flowmasters, or some other loud muffler on it than changing your manifolds to headers. Cheapest possible option (and I don't advocate it) is cheap long tubes with glass packs and turn downs bolted to the collectors. Ballpark minimum: $350- 400. You'll probably have to change your plug wires and routing as well.
04-13-2015, 04:05 PM | #7 |
laying low
You can achieve louder with just a muffler change. Much cheaper than putting on headers.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-13-2015, 04:12 PM | #8 |
It already has glass packs.
04-13-2015, 04:44 PM | #9 |
i ran flowmaster super 40`s on mine with ramhorns and it does sound real nice. its actually pretty difficult finding good fitting headers for our trucks that do not hang too low. im sure someone here thoough can give you a make and part # for you
1967custom |
04-14-2015, 01:10 AM | #10 |
Stock manifolds and 2 1/4 pipe flow good enough for 400 HP per the performance muffler shops i have talked too.
I looked up exhaust pipe flow rates on google one time and the sites i found also agreed with the performance muffler shops i talked too as well.. I had my headers for 20 years along with 2 1/2" pipe, i finally said to hell with it and went back to stock manifolds and 2 1/4" pipe, asside from not hearing that lumpy sound any more and per seat of the pants feel i can't tell any difference.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-14-2015, 01:40 AM | #11 | |
RAT1968 '68 Cab/'71 Parts
My '72 had ceramic coated stock manifolds, series 40's (Flowmasters), and 2.5" pipes plumbed all the way out the back. Here's what it sounded like at idle. https://www.youtube.com/watch?v=OxRy_sAmJYo Although I have headers on RAT, and I stuck with the series 40's because I like 'em. The muffler guy talked me into 2.25" pipes. I'm happy with the sound. RAT's a stocker. The '72 was pretty "cammed up". There's another vid or two of mine on YouTube with RAT's exhaust front and center...both driving and just sitting in the driveway... if you want to hear headers (Hookers) with 2.25 pipes and series 40's. But I'd definitely go with stock headers... and I'd feel good about 2.25" pipes. The sound really depends on who's listening, where you're sitting, where your mufflers (and pipes) are hung, how much sound deadener you've applied (that's for the driver and passengers), and which mufflers you decide to run.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
04-15-2015, 07:39 AM | #12 | |
