Old 04-13-2015, 01:28 PM   #1
primetime
primetime's Avatar
Saab's 5.3v8
my wife is allowing me to use her truck as a donor to my '68. (after i get her a new car of course).
this SUV is an AWD and has the half shafts coming out the side of the oil pan. can i still use this engine and trans or do i find a different 5.3v8 ?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 04-13-2015, 01:33 PM   #2
aod92
aod92's Avatar
Re: Saab's 5.3v8
You sure the half shafts are coming out of the oil pan? It should be the same 5.3 that's in the trailblazer since the Saab is built on the same platform
aod92 is offline   Reply With Quote
Old 04-13-2015, 01:35 PM   #3
michael bustamante
michael bustamante's Avatar
Re: Saab's 5.3v8
yeah ive seen that setup in the ss trailblazer.
anything is possable but that sounds like alot of work and youll probably have to switch to rack n pinion steering
1967custom
michael bustamante is offline   Reply With Quote
Old 04-13-2015, 02:16 PM   #4
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Saab's 5.3v8
Are you making the '68 all wheel drive?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-13-2015, 02:19 PM   #5
midniteblues
midniteblues's Avatar
Re: Saab's 5.3v8
that would be sweet
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-13-2015, 02:51 PM   #6
88Ironduke
Re: Saab's 5.3v8
I've got the same drive train in my Envoy Denali. Strange seeing the half shafts sticking out the oil pan no matter who you are! One side is the front differential assembly and passenger side had the 4wd lock up unit. My understanding is exhaust manifolds on these engines are very similar to Trailblazer SS manifolds. I'm eyeballing the LS power plant in my Envoy..... swap oil plans and rock on! Of course my better half already has put the cancellation to my thoughts on making my 72' a envoy powered truck....
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 04-13-2015, 07:56 PM   #7
hugger6933
Re: Saab's 5.3v8
Yep they do go through the oil pan. The 6cyl does too. The only problems I see in using that drivetrain is having to do something about the transmission but I'm sure you have already work that out. Yep the manifolds carry the same number for the TBSS and the other V-8 TB platforms so they ARE the best manifolds to have from what I understand. Good luck to you . Jim
hugger6933 is offline   Reply With Quote
Old 04-14-2015, 08:25 AM   #8
primetime
primetime's Avatar
Re: Saab's 5.3v8
No. I just want the engine and trans for my c10. However, I do believe it would cool to use the awd in a shortbed/ single cab Silverado. That would be a cool clone SS.
Old 04-14-2015, 09:10 AM   #9
EARNHARDT#3
Re: Saab's 5.3v8
I don't like AWD at all. I see you have a Silverado SS...weren't some of them AWD?
Old 04-14-2015, 09:15 PM   #10
primetime
primetime's Avatar
Re: Saab's 5.3v8
Naw it's not a real SS, that's why I put it in (). I was aiming to clone one, or should I say, 'tribute'.
Some of the SS SILVERADO's were awd early in the production years. But later on towards the end they came in 2wd. They were all extended cab trucks too. That's why I like when I see someone clone crew cabs like mine or single cab short beds.
Old 04-14-2015, 09:37 PM   #11
EARNHARDT#3
Re: Saab's 5.3v8
I'd love to own a 2006 Intimidator SS.
Old 04-14-2015, 11:36 PM   #12
57taskforce
All about them K’s
57taskforce's Avatar
Re: Saab's 5.3v8
Man you and me both. Most people don't even know what the truck version is, only the monte Carlo.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 04-15-2015, 11:20 AM   #13
bigmac73
bigmac73's Avatar
Re: Saab's 5.3v8
other than you being a NASCAR fan , not really much to that truck . IF GM is going to put Nr 3 name all over it, they should at least have the common decency to put in some power under the hood , 345HP... is an insult to the man and his legacy.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
