Old 04-20-2015, 10:36 PM   #1
Jaredchevyk20
What is the best way to prep a frame for por-15?
Hi, so in the near future I will be coating my frame with por-15. I have read mixed reviews about por. Some say it peels off and some say it works amazing! Now my question is what is the best way to roughen up the surface of the frame for the por to stick? Would sandblasting be the best way? or would sanding it with 80 grit or lower after wire wheeling it and getting all of the factory paint off of it. Let me know you guys experience with it. Thanks
Jaredchevyk20 is offline   Reply With Quote
Old 04-20-2015, 11:00 PM   #2
NJ C10 Guy
Re: What is the best way to prep a frame for por-15?
With stuff like this, with anything really, i tend to follow the directions the manufacturer provides. You'll get a bunch of different answers on forums but the fact of the matter is, these companies put money into research and development and have chemists in this case that understand how, when, and why you should apply their product(s). I don't think they would give bogus advice. Just my 2 cents...
NJ C10 Guy is offline   Reply With Quote
Old 04-20-2015, 11:07 PM   #3
greg64
greg64's Avatar
I did exactly this on my 64. Based on 10 years of using por-15 prior to this task, I did a lot of experiments. My experience is that the best application is to sandblast first, then treat the whole part with Metal Ready until it has a chalky white appearance. Then wash that off with water and dry everything. When dry, start applying the por-15. It really sticks.
The peel off problem happens if the metal is shiny and smooth. There's no tooth for the paint to really adhere to.
I'd agree with the previous poster to follow por's directions.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
frame, k10, k20, k30, por15
