04-26-2015, 01:41 PM | #1 |
'57 Porterbuilt 20" tires
I know this topic has been beaten to death, but the majority of threads I see or for later trucks. If there is a thread I missed, feel free to point me in that direction.
I'm setting up my '57 Chevy truck with the full Porterbuilt suspensioth I'll be using Centerline Smoothies that are being built as a 2 piece wheel instead of their usual 1 piece rim so I can get custom backspacing. There aren't a lot of options for the front because of possible interference with the suspension. I was told a 245/40/20 on the front. Quite a few different options on Tire Rack, although they are all car tires with no light truck options. I was also told 285/40/20 for the rear. There are really no good options in that size and nothing that matches up with a front. Has anyone used the Porterbuilt suspension on a trifive truck, and if you did what tire size did you go with? I haven't heard what they can do with backspacing, and I'm doing the tires and wheels first so I can mock it up with the bed to set the width of the 9" I'm having built. Any suggestions on tires? Backspacing ideas? |
04-27-2015, 02:41 PM | #2 |
Re: '57 Porterbuilt 20" tires
Id probably go with a 245/35 front. 285/40 should give you nice meat in the rear.
Toyo makes front/rears those sizes. And I wouldn't worry too much about one being car and one truck as long as you stick with a good brand tire. |
04-27-2015, 04:43 PM | #3 |
Thanks, I'll take a look. I'm not worried about the car vs. truck tires. I agree that as long as the are well made, it shouldn't make a difference on this project. My Jeep and Rover are a different story since they are beat up offroad.
04-27-2015, 07:38 PM | #4 |
I should have looked closer to you comment. The 285/40 is the size I can't find any options for. Checked on Toyo.com and Tire Rack only shows a couple, at least on their mobile site. They do show one in a 22". The do have a few in 245/20 or 245/22 which are almost 1.5" smaller.
04-28-2015, 04:22 PM | #5 |
Any other suggestions for a 29" tall tire for a 20"x9.5" wheel?
04-28-2015, 05:07 PM | #6 | |
Feel free to send me an email if you have any further questions: tech@pbfab.com Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-28-2015, 05:41 PM | #7 |
295-40-20 = 29.2" tall & will work fine on a 9.5" wheel.
04-28-2015, 08:57 PM | #8 |
Thanks, quite a few choices for that. Any recommendations for a front size that won't interfere with the Porterbuilt front on a 8.5" rim?
04-29-2015, 02:49 AM | #9 |
Based on a 295-40-20 rear? I would do 245-40-20's & go from there.
