05-04-2015, 07:18 PM | #1 |
coolant flow direction
Can someone show me a diagram of coolant flow through a big block please?
Specifically what I'm doing is replacing my standard direction water pump with a reverse flow pump to use with the new Kwik Performance serpentine kit. The problem I'm facing is that the inlet that I had my upper heater core hose going to on the standard pump is not on the new reverse flow pump. This new pump is only tapped for the small hose that runs to the front of the intake manifold. The new pump does not have the fitting location for where my upper heater core hose goes. Where does that critter go? Maybe I can get some pics up.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
05-04-2015, 11:28 PM | #2 |
60-66 Nut
Re: coolant flow direction
I may be wrong but I believe that hose would be the return from the heater core. In which case with your particular water pump, that hose should go directly to the passenger side radiator tank.
05-05-2015, 12:04 AM | #3 |
05-05-2015, 11:09 AM | #4 |
Thanks for the pic GRX.
Capt, ok, but I don't have a termination point for the upper heater core hose. Per the diagram shown by GRX, I don't have another inlet point on the pump. Just the little one on top that goes to the front of the intake like in the pic. Maybe I need to find a diagram of a mid 90's truck hose route? That's what this serpentine kit and water pump is based on.
05-05-2015, 01:20 PM | #5 |
The flow is going to be the same, just with the pump turning the other way. The pump is still pushing coolant into the block, all the other fittings outside of that are coming into the pump or suction. So to answer your question about the heater hose..............to the radiator
05-05-2015, 01:57 PM | #6 |
is a fungineer
Serpentine pump should be reverse ROTATION, not reverse flow.
LT small block was reverse flow.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
05-05-2015, 03:56 PM | #7 | ||
05-05-2015, 04:19 PM | #8 |
motor exploder
Here's what I did, same situation. I have a reverse rotation pump from Edelbrock. All you're doing is eliminating the bypass hose that goes from the intake directly to the water pump.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-05-2015, 04:33 PM | #9 |
so upper hose goes to intake, lower hose goes to pump.
thanks a ton Boss no wait, the lower needs to go the intake and the upper goes to the pump right?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 05-05-2015 at 05:21 PM. |
05-05-2015, 10:38 PM | #10 |
05-06-2015, 12:47 AM | #11 |
60-66 Nut
Some of the squarebody radiators have the heater hose return nipple on the passenger side radiator tank. I was thinking some of the '67-'72's did as well?
05-06-2015, 07:08 AM | #12 |
motor exploder
That's what I did - there is no provision for the 'bypass' hose to the intake from the water pump. Fluid goes to the heater core from my intake, comes back from the heater core through the inlet on top of the water pump - that's the only way to do it, since on my water pump that's the only fitting there is. On my firewall the fitting closest to the motor goes into the heater core, the next one over brings it back to the pump.
