Old 05-10-2015, 11:20 AM   #1
trukman1
Read Disc Caliper Question
Quick question. Since I swapped the rear brakes on my 14-bolt to the 3/4 ton discs, is there a caliper with the e-brake that will fit the 3/4 ton rotors? (They are the same as on the front of the late '70's 10 and 20 series.) Thanks for your time.
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 05-10-2015, 11:51 AM   #2
snj8198
snj8198's Avatar
Re: Read Disc Caliper Question
78-79 Caddy Eldorado calipers. They have the self adjusting e-brake system but IIRC I believe people were having problems with this feature so many scraped the idea of using them. It's been a while since I did my homework on the subject but the problems I read were enough of an issue for me to opt out of using the Eldo calipers and just use 3/4 ton front truck calipers. I have been using a line lock for ebrake detail but now I have a HAD t-case ebrake about to go in.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-10-2015, 12:23 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
My truck had elderado calipers on it when I bought it. The parking brake didn't hold, and braking was not the best. I installed the larger c20 calipers. Braking is a lot better, but still no parking brake.
I would not waste the time or money with trying to use the elderado calipers.
I am still looking for options for a parking brake. I would love a drive line parking brake, but my transfer case has a slip yoke.
95 S_Trucker is offline   Reply With Quote
Old 05-10-2015, 01:18 PM   #4
snj8198
snj8198's Avatar
Mine does too but you can get a flange to replace the yoke. Snoop around High Angle Driveline's website.
http://www.highangledriveline.com/e_brake.html
Steve
Old 05-11-2015, 03:53 AM   #5
andrewmp6
If you don't have a state inspection you could run a hydraulic parking brake.
andrewmp6 is offline   Reply With Quote
Old 05-11-2015, 10:09 AM   #6
snj8198
snj8198's Avatar
ya, a line locker. I did this for a few years. The first one worked well and lasted a few years but the second one died on the sixth time using it. When it died the truck to a ride out of the driveway, over the rock retaining wall which was a four foot drop, across the lawn, and into a tree. lucky it's height cleared the large rocks as it bounced over and the rear bumper saved body damage.
Steve
Old 05-11-2015, 09:22 PM   #7
72MARIO
72MARIO's Avatar
I have been using the caddy calipers for 7 years. I don't run the truck in the winter but have had no problems with them. Still original pads. Over 65000 miles towing and hauling always.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-11-2015, 09:25 PM   #8
72MARIO
72MARIO's Avatar
Example...
2005 TAHOE DD
Old 05-12-2015, 12:51 AM   #9
snj8198
snj8198's Avatar
nice looking truck Mario. Good to see it being worked.
Steve
Old 05-16-2015, 12:50 AM   #10
'68 Newtricks
'68 Newtricks's Avatar
Alternative to those doing discs but haven't bought anything yet. I would like to try this but for now I'm running 1/2 calipers in the rear. They are 1/2 ton sized pistons but came on an 8 lug front.
http://www.ebay.com/itm/310679487802...%3AMEBIDX%3AIT
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-19-2015, 02:44 PM   #11
Jonboy
Slots go on anything!
Saw these on ebay: http://www.ebay.com/itm/GM-Metric-Re...3D141016773439
1974 Jimmy- 5.3/4L80e/NP241
Old 05-19-2015, 02:54 PM   #12
Redcap
Pinion brake on the back of the T-case for Ebrake/parking brake.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 05-19-2015, 03:22 PM   #13
newstedcomeback
newstedcomeback's Avatar
Originally Posted by Jonboy View Post
If you order these, You should make sure thet they are the right size. GM has more than 1 standard size for calipers. you can measure the distance between the mounting slide pins. the trucks use the 7" and i believe the smaller one is 5". its a very good price for a set of new calipers So I would send a message to the seller and ask them to measure the distance between the slide pins.
Better to do some research than to waste $
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877
2018 Silverado 1500 5.3 LTZ Z71 - daily driver
2019 Tahoe Z71 5.3 - (Wifes daily driver)
newstedcomeback is offline   Reply With Quote
Old 05-19-2015, 04:03 PM   #14
Jonboy
You are probably right. I saw them listed in another post, and the price looked right. Hopefully it is not too good to be true.
edit- just messaged the seller. I will post the answer.
Old 05-21-2015, 07:48 PM   #15
v30crewcab
v30crewcab's Avatar
I run a 02 14bolt in my crewcab, nice disc brakes on them. best way to do it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-22-2015, 10:59 PM   #16
whitedog76
Go to any GM dealer and buy a bracket kit from a 99 and newer 2500 truck.
Then go to RockAuto and buy Calipers & Rotors.
You can also look into a 03 and newer van setup. It'll be a little pricier though.
Depending on your axle, you may have to have an adapter or weld on flange made.
whitedog76 is offline   Reply With Quote
