05-12-2015, 04:29 PM | #1 |
Did any of the 67-72 K10 4x4s come with a 3-speed manual on column?
I've seen grannys and automatics but not 3 on tree.
Did any come like that? |
05-12-2015, 04:52 PM | #2 |
Re: Did any of the 67-72 K10 4x4s come with a 3-speed manual on column?
Yes, 67-72 K-series (4x4) Pickups, Suburbans, Panels and Blazers all came standard with a 3OTT column shift setup as base equipment.
While sellers of such trucks tend to think of them as valuable rare variants in reality they are speed range limited.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-12-2015 at 04:58 PM. |
05-12-2015, 09:28 PM | #3 |
I had a 67 283 4x4 3 on the tree shortbed
05-12-2015, 09:33 PM | #4 |
All about them K’s
My dads 71 k/10 was a 3ott.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-12-2015, 10:07 PM | #5 |
Blazers came coupled to a Dana20 transfer case. Pickups and Suburbans (I think all of those) came with NP205
05-12-2015, 10:30 PM | #6 |
Thanks to all.
I'm going to look at a 72 4x4 and I wanna make sure it was originally a 4x4 or at least on the right year k10 frame. I read in another post that the rear should have staggered shock mounts on the back and the frame should be straight (not curved to the outside) over the rear-end area. Any other things I should look for? How about the engine frame mounts? Should they be like the SBC or 6-cyl mounts on a 67-72 C10 or do they have the cup-style mounts like the later models and 72 BBC mounts? It's 3OTT and has a SBC. He doesn't have a title, just a bill of sale. I'm not sure if the SPID sheet is there or not either. |
05-12-2015, 11:13 PM | #7 |
My truck is a 3ott and I wouldn't have it any other way. It is fun to drive (and good for dates if you have a bench seat!) but as the other member said, it's "speed challenged."
It's hard to change gears in a hurry....but with the low gearing those 3ott's normally got, there wasn't much of a hurry you could ever be in. |
05-13-2015, 07:44 AM | #8 |
If it's not authentic, either the 4wd crossmembers were swapped-in or it's a later 4wd frame. The crossmembers were riveted, so look for that. The '73-up frames were longer up front of the cab, so the frame tips would be cut and the core support moved back. Then, there's the shocks being both to the front.
05-13-2015, 12:03 PM | #9 | |
All about them K’s
05-14-2015, 08:39 AM | #10 |
GMC Dreamer
They sure did. My dad had a 69 4x4 SWB with a 307 & 3-on-the-tree.
2000 Silverado. 5.3L. 4" RC lift. 18" Moto's with 35x12.5 Nittos. SOLD: WAY TOO MANY TO LIST HERE [/FONT][/SIZE] |
05-14-2015, 10:56 AM | #11 |
Check Vin too. Should start with ks or ke
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
05-15-2015, 12:06 AM | #12 |
Mine is a 72' and came stock with a 250 inline 6 and a 3ott, although the six is long gone and a 383 resides in there now.
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 |
05-15-2015, 06:47 AM | #13 |
Is the Saginaw still behind the 383? Bless it's little heart
05-15-2015, 10:57 AM | #14 |
It sure is!
04-18-2024, 07:24 PM | #15 |
Hey everyone, I am bringing this thread back from the dead.
I was always under the impression that the Rockwell T-221 transfer case that was available from 1967 to about 1969-ish was ONLY available behind either the SM-420 in 1967 only, and the SM-465 from 1968 to 1969. Beginning in 1969 with the NP-205 phasing out the T-221, there was now an option for automatics as well as 3 speed on the tree manual transmissions. Has anyone ever seen either a 3 speed or an automatic transmission coupled to a Rockwell T-221? Was there another even more obscure transfer case available in limited configurations from 1967 to 1969? Inquiring minds want to know. Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
04-19-2024, 12:23 AM | #16 |
All about them K’s
I know automatics are out of the question with the 221 but I’ve never really given thought to the three on the tree with a 221. I’m gonna say it’s probably not likely.
04-19-2024, 10:42 AM | #17 | |
Automatic trans in a K-series was not an option in 67 or 68 according to these info kits. https://www.gm.com/content/dam/compa...olet-Truck.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-19-2024, 11:18 AM | #18 | |
Clay
04-19-2024, 02:40 PM | #19 |
here u go - this was a rare truck already with all its other options, but a 4-spd was not one of them.
04-19-2024, 02:42 PM | #20 |
All about them K’s
Very cool Mark, thanks for sharing that.
That is a bad ass spid. Manual throttle, Buckets, No spin rear, Posi front, shoulder belts??? Damn the cool factor is real! Pretty weird to have ordered the 327 and axle upgrades but no 4speed.
04-19-2024, 03:52 PM | #21 |
Wow, what an option package. Did that truck get saved? How long have you been hanging on to those photos?
04-19-2024, 04:51 PM | #22 |
Quite a while. I think this was up for sale several years ago, if I recall correctly. But I don’t know if anyone ever rescued it. I do remember seeing some discussion on here about its front axle posi. Yep, it’s loaded.
04-19-2024, 05:12 PM | #23 |
Man, that thing is incredible! I guess that solves the 4-speed vs. 3-speed mystery for me. For some reason, I just find the Rockwell transfer cases interesting. I know that a lot of folks out there switch to NP-205's, but there is just a cool factor with the Rockwell's that I can't seem to shake.
I posted this in the 4x4 forum a few months ago, but back in January, I was able to score a NOS Rockwell T-221. It had been sitting in a warehouse since the early 70's and was purchased as part of the entire inventory by a guy in the early 90's. He in turn had it setting in a shed ever since. It still has the cardboard protectors on the splines, and when I cracked open the top of the case, it was pristine inside with the machine marks still visible on the gears. I would love to be able to see the adapter that sits in between the 3-speed transmission and the Rockwell though. That has to be a very rare thing indeed! Here are some pics of the NOS Rockwell that I have. Clay Clay
04-19-2024, 05:16 PM | #24 |
I have a core Rockwell T221 transfer case and SM 465 married unit. Gotta be 1968. Possibly GMC or Canadian. I bought it at a junker in Tucson [long way from the Great White North] but IIRC the donor truck was a GMC. Yes it's a 465, not a 420. I'm not hallucinating.
[Well not about that at least.]
04-19-2024, 05:17 PM | #25 | |
That is what I was thinking too....I really wonder why someone would order that particular setup.
