Old 05-21-2015, 10:38 AM   #1
Ol' Chevy
1968 C20 transmission swap advice
Howdy,
I have a 1968 C20 4x4 with a 4-speed transmission. The diff's are geared at 4.56. It really screams going down the highway, and the gas mileage is terrible. I was considering re-gearing to 4.10, thinking that may at least quiet her down on the highway. I am now wondering if I can achieve the same result by swapping out the 4 speed transmission for a 5 speed. Has anyone done this? Did you gain fuel mileage? Lose power? Any input will be helpful. Thanks.
Ol' Chevy is offline   Reply With Quote
Old 05-21-2015, 12:17 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: 1968 C20 transmission swap advice
The NV4500 is the good swap candidate, 2 different chevy versions, one has a lower first gear. Both have OD. Both will work. Used in 90's trucks. I have not done it myself.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-21-2015, 03:20 PM   #3
newstedcomeback
newstedcomeback's Avatar
The NV4500 would be the best choice, However it is not a very simple conversion. there is alot involved such as the clutch linkage, drive shaft length, transfer case adapter, finding a 4x4 version of the NV4500. the transfer case that came with the NV4500 are all for the drivers side front diff so you would need a conversion adapter for the NP205. alot of time and $ will be involved, but in the end you will be very happy.
as far as re-gearing the rear end, you would have to do the front axle as well to Keep the gears the same for 4x4. If you cant do the gear setup yourself, It can be pretty expensive.
Overdrive is a wonderful thing. I have a 700r4 on my truck, right now its is in the process of being put back together, but when I went from a th350 to a 700r4 it was a great upgrade. have you considered swapping to an automatic? because you can find 700r4's all day at junkyards, many of them have np208's already attached which is set up for the pass side front diff. that combo has a great low range and Overdrive. prettymuch a win-win. that would be a much simpler conversion in my opinion. 700r4's are not the strongest, but they were used in 3/4 ton trucks and suburbans and the np208 was used in 1/2 3/4 and 1 ton trucks. my buddy's CUCV has one in it.
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877
2018 Silverado 1500 5.3 LTZ Z71 - daily driver
2019 Tahoe Z71 5.3 - (Wifes daily driver)
newstedcomeback is offline   Reply With Quote
Old 05-21-2015, 06:51 PM   #4
jeffahart
jeffahart's Avatar
I can tell you I had 4.10 with the SM465 and 33s and loved the setup. I now have 4.56 with 33s and it's screaming metal now for sure. But going to 4.10 is the wrong side of the carrier break and you will be into it for some money. As long as you are spending the bucks, might be better to go a bit taller gears 3.73 than 4.10 and adjust down with tires. And I do think the 4.56 gears are more noisy, they seem to bring out the harmonics in everything. If you are touching the transmission I would go automatic. What more could you want for compound reduction and overdrive? I feel like you have the best manual truck transmission you can get. And of course it all depends... on... What you use the truck for... your skill level for conversions.... your wallet depth... and level of PATIENCE!
White K20
jeffahart is offline   Reply With Quote
Old 05-21-2015, 11:10 PM   #5
obijuan
put some 38's on it.
obijuan is offline   Reply With Quote
Old 05-24-2015, 11:05 AM   #6
'63GENIII
'63GENIII's Avatar
While the 4500 isn't a real straight forward swap depending on the transfer case combo that you have, it really is a cool set up. I have 4:11's with 35" tires and the truck used to howl down the freeway at 70 - 75. It just kid of lopes along comfortably now. I went to the 4500 from a TH400. I also had a divorced T221 at the time. I now have a divorced NP205. Huge difference. The truck seems to run around 2200 - 2400 where as it used to run around 2900 - 3000 rpm.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
