Old 05-21-2015, 02:18 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
sm465 neutral saftey switch
Just trying to button up some of the wiring before it goes in for inspection. I have two switches on my transmission, one I would say is for back up, the other a neutral safety switch? Side being reverse top being neutral or the other way around?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 05-21-2015, 02:56 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: sm465 neutral saftey switch
My neutral safety switch is mounted on the pedal assembly (On my K5). My reverse switch is on top. What year is your SM465?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-24-2015, 04:08 PM   #3
magicoolbus
magicoolbus's Avatar
Get you continuity tester out. Revere switch should go to ground when in reverse.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 05-24-2015, 08:35 PM   #4
Wildstreak
Wildstreak's Avatar
I got the reverse lights figured out, theyre the side switch. Now I cant figure out the neutral safety. I have two trucks that had manuals and neither have a switch anywhere on the clutch pedals. Can anyone else confirm that is the location of the switch or did some not have them at all? I need a neutral safety switch in order to pass inspection, any ideas where I could get one and adapt it to my pedal?
57 chevy 4x4
68 burb 2wd:
Old 05-24-2015, 10:34 PM   #5
Wildstreak
Wildstreak's Avatar
OK had a beer and an idea popped into my head, now its not the most professional job but it works. So my idea was to take the brake switch from a parts truck and mount it to the clutch, Ill make a better bracket later but it works so far.
57 chevy 4x4
68 burb 2wd:
Old 05-25-2015, 02:17 AM   #6
magicoolbus
I did a very similar mod. When I added a speedo stat cruise control, they have this mickey mouse set up for disengaging the cruise if you step on the clutch before the brake pedal. It is a sensor that goes around a plug wire and kicks off the cruise if the revs go to high. Not my idea of a good failsafe, so I put another brake light switch on the clutch pedal to disengage the cruise.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
