Valve cover stud question
Hey guys,
I'm getting a new valve cover for my L6 250, and I wanted to put some wing nut type fasteners. What's the length that I need to get? It's the stock height and length, just shiny. |
Re: Valve cover stud question
1/4" - 20 x 3/4" long should work fine or 1/4" -20 by 1" long depending on the wing nut length.
Basically you want about 1/2" into the head and the close to the same in the wingnut.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-26-2015 at 09:59 AM. |
Never Ending Projects
I bought a set for a V8 engine and only used 7 of the tee handle ones.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Tags |
chrome, gasket, help please, studs, valve cover |
