Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-06-2015, 10:00 AM   #1
shortbed70
shortbed70's Avatar
Drag radial?
Ordering a set of drag radials to help the truck get off the line.. 255-60-15 what pressure would be a good all around to start? It's a street truck but will be towed to the track!as you can see by the time I need more traction!!!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-06-2015, 10:25 AM   #2
Ont67shortbox
Re: Drag radial?
I had drag radials, started at 16 lbs, then went up or down depending on track
Ont67shortbox is offline   Reply With Quote
Old 06-06-2015, 11:01 AM   #3
shortbed70
shortbed70's Avatar
Re: Drag radial?
Thx kind of excited to see if it will 60' with air ride suspension.. Wife thinks I'm crazy for putting drag radials on a truck with air ride built to go to shows and cruise....
Troy
Big Red Dog build
Old 06-06-2015, 12:59 PM   #4
Super73
Super73's Avatar
Re: Drag radial?
How wide is the wheel? That had a role in tire pressure.
With a12" wide wheel and a 315/60/15 dr, mine likes 12lbs cold, 13lbs hot.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-06-2015, 01:21 PM   #5
shortbed70
shortbed70's Avatar
Re: Drag radial?
8" wheel
Troy
Big Red Dog build
Old 06-07-2015, 01:21 PM   #6
Super73
Super73's Avatar
Re: Drag radial?
Being tire contact patch is larger than rum diameter, I would say start at 16lbs.
Old 06-10-2015, 11:06 PM   #7
shortbed70
shortbed70's Avatar
Re: Drag radial?
Radials will be in Friday! Might be able to get them mounted but the dreaded rain (every weekend since end of April) is forecasted again!!!
Troy
Big Red Dog build
Old 06-13-2015, 05:18 PM   #8
shortbed70
shortbed70's Avatar
Re: Drag radial?
Well they are here... Also noticed my time slips say 1320... Ha only 1/8 mike track!! Maybe if the rain ever stops I can try them out...
Troy
Big Red Dog build
