Old 06-10-2015, 11:10 AM   #1
pdawg
700R4 Shift Indicator
Quick question - I'm having a 700R4 built up for my '72 C10 & was wondering about the shift indicator. LMC sells replacement lenses, but the one for the 700R4 says it's for a tilt column - which unfortunately - I don't have. Can anybody advise me what I can do so I have the proper 4 speed indicator? Also considering putting the trans. in myself. Is it a pain to do with the coolant lines, etc.? I know I'll have to move the cross member back & re-drill the frame, shorten the drive shaft, & ensure the TV cable is properly adjusted, but am I missing anything else that could bite me? I know I'm not the first to ask, but if you could save me some hunting that'd be great!
Many thanks!
Perry
pdawg is offline   Reply With Quote
Old 06-10-2015, 07:53 PM   #2
NorCalC20LWB
Re: 700R4 Shift Indicator
Thinking about doing the same thing myself. There is a very detailed post about all that is involved for the swap to a 700R4, but I can't find it right now. It is in one of the FAQ areas, but not sure which one, maybe someone else can post the link??
NorCalC20LWB is offline   Reply With Quote
Old 06-10-2015, 09:24 PM   #3
SoCoC10
SoCoC10's Avatar
Have you checked with Shiftworks for your indicator, detent needs? I'd recommend a 200R4 over the 700. Better 1-2 shift, use your TH350 or Powerglide driveshaft yolk and no drive shaft lengthening or shortening needed!
I have a junkyard $75 200R4 with a Grand National converter, Corvette SuperServo, TCI lockup harness, Transgo Shiftkit and Shiftworks conversion kit in my Chevelle and it it holding up to over 500 flywheel horsepower. Just my $.02
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 06-10-2015, 10:04 PM   #4
pdawg
I haven't heard of them until now (thanks!) so I'll give them a try. Re: 200 vs 700 - I've already taken in the 700 to get built up, but thanks anyway for the input.
Old 06-10-2015, 10:06 PM   #5
pdawg
I'll have a look & see if I can track it down. I was just hoping to save some time hunting for it. Thanks!
Old 06-11-2015, 08:08 AM   #6
Katrina/10
Katrina/10's Avatar
I put a 700 in my truck also, using the original non-tilt column. I looked all over for overdrive shift indicator lenses, and could not find any. I don't know why they would be available for tilt only.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-11-2015, 12:02 PM   #7
NorCalC20LWB
Found the link, very nice and detailed write up!
http://www.google.com/url?q=http://6...5BqdGrtLPZkCMQ
Old 06-11-2015, 12:24 PM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: 700R4 Shift Indicator
I took the original 3 speed auto lens out of mine, used it for a pattern, traced that onto a piece of clear lexan, then I used the clear acrylic "Ididit" Over drive indicator and applied that to the Lexan, it looks kind of Odd, but it works, at least until I can find a better substitute. I'll post a picture later, as I am at work.
Have a good one!
Ben
snipescastle2 is offline   Reply With Quote
Old 06-11-2015, 12:30 PM   #9
pdawg
That's awesome! Thanks for the help! Really looking forward to the new transmission. It should really wake it up - especially when I get my new posi
Old 06-29-2015, 09:59 AM   #10
snipescastle2
here's a few pictures of what I did to get a temporary indicator, until I can get one that's better, the last pic shows some discoloration, that's from super glue I used to hold the lexan in place, I used clear RTV to attach the indicator to the Lexan....Enjoy!
Ben
Old 07-01-2015, 11:49 AM   #11
pdawg
Ben
I think you made a great job of it! Thanks for the pic's! I've just started to take my TH350 out & will hopefully be putting the 700 in on the weekend. Fingers crossed all goes ok .
