06-20-2015, 10:14 AM | #1 |
Help with 22.5 Wheels/Tire size
All,
Need help trying to figure out if an 11R22.5 tire will fit with these wheels on a 1960 C60. It currently has 8.25-20 bias ply rubber with the widow maker RH-5 two-piece split rims. Upgrading to 22.5 steel wheels. The "stock" width is 6.75 which you can only run a 10R22.5 on. The wheel builder says they can make 7.5 or 8.25 widths on request to run the 11R22.5 size tire. I'd like the larger tire as I have a single speed rear end and would like to be able to run at 55-60 without turning the engine near 3000 RPM. I am afraid the rear dual set up will not clear either the leaf springs and/or they tire/wheel combo will touch each other once the duals are bolted together. jumpsoffrock bought a set of the aftermarket 28160 wheels and I am tracking the issue with the lug holes. Thanks for the help.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 06-21-2015 at 01:40 AM. |
06-20-2015, 11:36 AM | #2 |
Re: Help with 22.5 Wheels/Tire size
Those old wheels aren't that hard to change and not dangerous if you do it right.
It's up to you though ....
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
06-20-2015, 02:15 PM | #3 | |
Honestly, the 20 inch rubber options aren't really there and I think I'll not mind updating to radial rubber. I would like to run taller tires, but not sure they'll fit on the rears.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
06-20-2015, 05:11 PM | #4 |
the lock ring multi piece wheel are fairly benign, the rh5 SPLIT ( in the center where you cant see....) present a Much HIGHER risk.
06-20-2015, 05:17 PM | #5 | |
Of course it's also a good idea not to stand over them when airing up, just in case The rest of it is just knowing how to go about it without wearing yourself out too much. They do require a fair bit of prying and hammering (in the right places). I had a C-50 log truck and had a lot of flats, so I got plenty of experience over the years. I have no idea what's available in 20" truck tires today. Back then I bought used school bus tires with about 50% tread for $25 each
06-20-2015, 09:26 PM | #6 |
I'm not completely clear on what you're asking. I hope I can help.
But would pictures of my setup help? I couldn't find 11R22.5 for my rims(that's what I wanted), so they got me 235/80-22.5 . -->Will they fit the rim? The guys at my local tire shop(been same-family ran for 75+ years) said the 11R22.5 should fit(not absolutely will; "should"), but they're overkill and hard to find used(and very expensive new). -->Will they touch each other? I really don't have experience.....but I just doubt it. --> Will they touch springs? Don't know, probably not on my truck. I may try and take my truck by a tire shop the next day I have off and ask them those three questions(they probably can't answer #3). I'll get back to you if I can manage. Additionally, With my 4-spd(SM420) and a (6.61 Low) (4.86 high):1 rear end gear, I achieve 55mph @ ~2500 rpm. This is verified mathematically, but not on gauges. My speedometer didn't work and is now completely removed from the truck. I had to change the rear carrier to get those ratios. With my previous high gear (6.51:1) I calculated the 11R22.5 that I was shopping for to barely put me at 55mph @ 3000. I was not satisfied. Then I bought a used differential carrier..... Last edited by jumpsoffrock; 06-20-2015 at 09:36 PM. |
06-21-2015, 12:59 AM | #7 | |
I was told the 28160J wheel that is offered by wheels now, which appears to be what you ended up purchasing comes in the 6.75 inch width. Most tire folks are telling me that a 11R22.5 cannot fit a rim that narrow. It needs to be either a 7.5 or 8.25 width. Wheels now can make the 28160J in either width per request of the customer, but I am concerned if I go with the wider rim, I will have issues with the tires clearing each other in the rear or the inner tire clearing the leaf spring. It all depends on the offset they build the rim to I suppose. I asked for a spec sheet on the rim dimensions but they had not sent it yet. Maybe early next week. Thanks for the pictures and the input. Looks like there is plenty of room between the rear wheels so that shouldn't be a problem. Looks like If I am going to have trouble, it will be on the leaf spring side as that space could get a little tight with a wider rim/tire combination.... I have inquired about a ratio change as well. I have the 261 I6. I'm hoping to sort of split the difference so I can run 55-60 without running the engine so high. Thanks again. Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 06-21-2015 at 01:39 AM. |
06-22-2015, 02:00 AM | #8 |
jumpsoffrock....your wheels are the 6.75 width correct?
06-22-2015, 11:10 AM | #9 |
Yes I believe they are...they are standard as to how they are advertised.
06-22-2015, 05:01 PM | #10 |
Radials would be much nicer. Just think of how much each wheel/tire will be, and how much less overall rotating mass there will be. Should add up to better mileage as well. Also, if I had a blowout on the side of the highway, how many 20" tires will be available to get me back on the road? Handling is also a consideration. I'm seriously considering the 28160J's as well, but the cost of the wheels, $245 a piece, and new tires, has kept me on the fence for now. I was hoping to find a good donor vehicle I can use the axles, wheel, and tires from. I'm not done looking through all the local scrap yards and farms yet either.
Bill |
06-23-2015, 12:16 AM | #11 | |
I have been looking around for the wheels too. I have only located 2 of them. I hate the cost of this stuff, but what else can you do?
06-23-2015, 12:21 AM | #12 | |
Looking for the distance between your inner rear dual wheel rim lip to the leaf spring pack....like in the attached photo. I would appreciate it if its not too much trouble. My truck has the RH-5 20x6.0 wheels and the distance on mine is about 3.5 inches on one side, and 3.75 on the other. Just want to do some quick math to make sure the extra rim width (.75) and 10R tire (probably about a .75 bulge outside the rim lip will clear my spring packs. As you can see there isn't a tone of room there. It looks about the same as yours already and my rims are supposedly only 6.0 wide. Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 06-23-2015 at 12:23 AM. Reason: added picture |
06-23-2015, 03:09 PM | #13 |
I hope these photos are good enough. It wasn't very easy to get any better. It looks like the problem would be in the shackles, possibly.
Let me know if I can help otherwise. Pic 1: From spring to wheel rim Pic 2: From spring to Tire Pic 3: From U bolt to rim |
06-23-2015, 09:23 PM | #14 | |
I think I'll be in good shape. When I get it all set up, I'll take pics and post. Thanks for the help. Jonathon
07-21-2015, 11:05 AM | #15 |
Here is the semi-finished set up.
10R22.5 Goodyear G186 tread recaps and 28160J wheels from Wheels Now Inc. The wheels/tires fit just right. I did not have the lug-hole size issue that jumpsoffrock did. Wheels bolted right up after painting and tire mounting.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 07-21-2015 at 11:08 AM. Reason: missing attachment |
07-21-2015, 11:39 AM | #16 |
Nice truck!
I think that's about the same wheelbase as my 1965 GMC. I had a swivel log bunk mounted right over the axle, and a homemade log loader that took up about four feet of frame right behind the cab. I also had it set up as a bobtail for a while without that loader, and could haul 12' logs comfortably - longer if not too many.
07-21-2015, 12:40 PM | #17 | |
You got photos of this '65 GMC you mention? Would love to see it.
07-21-2015, 01:33 PM | #18 |
Would have to find them and scan them - that was long before the days of digital cameras
07-21-2015, 01:44 PM | #19 |
07-21-2015, 03:05 PM | #20 | |
Thanks. Have a few other things to sort out on it mechanically, then I'll post some more when I get her working. (wood bed is a tad soft right now....)
08-04-2015, 09:03 PM | #21 | |
Keith. |
08-05-2015, 07:13 AM | #22 | |
The big reason I had to switch the wheels was due to the old Firestone RH-5 split wheels. I got into this project without the knowledge of those wheels and found by talking to most experience big-truck hobbyists that they are not recommended due to safety reasons and thier history of accidents. I like the new set up. I do think the truck seems to run/ride a little better and because they are taller, I get a few MPH out of it. The larger tires look a little nicer too in my opinion. I was hoping to get a set of the original style tubless wheels, but I couldn't find a full set. I am ok with these ones. I think they look ok now that I've had a chance to look at them for a while.
08-05-2015, 04:20 PM | #23 | |
Keith. |
08-05-2015, 11:22 PM | #24 | |
I think the radials are a good improvment if you're going to run it more often than not.
05-27-2017, 08:00 PM | #25 | |
