Old 06-28-2015, 01:29 AM   #1
ihatericeburners
ihatericeburners's Avatar
power steering pulley alignment problems! with pics!
Hi there. Ill try to keep it short and sweet!
I cant figure out if I havean incorrect bracket, if my pump is too long, or if my pulley has an incorrect amount of offset. Just looking for some guidance!
69 c10 with a 350, running a short water pump. Got a/c aswell.
help! Help!
ihatericeburners is offline   Reply With Quote
Old 06-28-2015, 09:35 AM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: power steering pulley alignment problems! with pics!
you have the wrong crankshaft pulley
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 06-28-2015, 10:45 AM   #3
old Chevy guy
old Chevy guy's Avatar
That would be my call as well is the alternator on the drivers side like stock? My truck with 350 has short water pump and a 2 piece bottom pulley. the water pump and alt run on the inside toward the motor and the ps runs on the outside I think, and there are 3 grooves on the bottom pulley. I can try and post a picture if that would help?
old Chevy guy is offline   Reply With Quote
Old 06-28-2015, 11:16 AM   #4
jjzepplin
jjzepplin's Avatar
Right pulley-right pump- wrong bracket. Should be this one.
You have what looks to be the long water pump bracket.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-28-2015, 12:26 PM   #5
Mmorgan32
Mmorgan32's Avatar
If it's and ac truck your crank pulley will have 3, at least mine does
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 06-28-2015, 02:40 PM   #6
68panelman
68panelman's Avatar
Every pulley lines up Except the fancy crank pulley. I'd say that's the culprit.
68panelman is offline   Reply With Quote
Old 06-28-2015, 06:35 PM   #7
jjzepplin
jjzepplin's Avatar
Crank pulley is right. Ran the same one for ten years. I did not see the water pump pulley but it should have two grooves.
Old 06-28-2015, 06:48 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: power steering pulley alignment problems! with pics!
Correct alignment with correct small block pulleys with PS,AC. Cranck has 3 grooves they are bolted on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-28-2015, 09:43 PM   #9
ihatericeburners
my water pump pulley has three. but I will only use two for a/c and alt.
I have new alt and a/c brackets from allen grove and they align both correctly.
the issue is the power steering set up. Thanks!!!
Old 06-28-2015, 10:22 PM   #10
ihatericeburners
And I found this. It looks like I would need the one the one on the left, and have the one on the right.
Old 06-28-2015, 10:28 PM   #11
Grumpy old man
Grumpy old man's Avatar
Go to Copher's upullit in Clearwater they used to have stacks of them on the shelves
Grumpy old man is offline   Reply With Quote
Old 06-28-2015, 10:38 PM   #12
Andy4639
Old member
Andy4639's Avatar
These power steering pumps where installed on millions of GM products during these years. You may have a Buick pump who knows they look alike and without knowing which valve is in it you could have a Pontiac pump. The brackets are just like the pumps who knows what they fit.
It's not a big block truck pump either because it doesn't have the reservoir on the drivers side fender. Just for info.
Old 06-29-2015, 07:17 AM   #13
jjzepplin
jjzepplin's Avatar
I've got the pump-brackets and pulley for $50 Come get it and no more worries. Came off my 72 Short water pump system.
Old 06-29-2015, 05:42 PM   #14
ihatericeburners
Dang.... I was just at Fords Garage yesterday!
How much to ship to 34669?
Old 06-29-2015, 09:44 PM   #15
jjzepplin
jjzepplin's Avatar
It is the pump in the pics. Not sure how much to ship and don't have a day off any time soon. I would imagine about $20 or so for shipping. Might fit in a flat rate medium box if I take it apart. Those are about $13.
Old 06-30-2015, 12:20 AM   #16
butcharoot
Try Dennis's Chevy Truck Parts in Pinellas Park, 727-541-2903.
butcharoot is offline   Reply With Quote
Old 07-08-2015, 04:56 PM   #17
ihatericeburners
Any opinions on this barcket/pulley combo:
And
thanks again!
Old 07-12-2015, 01:04 AM   #18
ihatericeburners
If anyone was wonder...
