09-05-2003, 07:46 PM | #1 |
Wanted: 71 K20 Brake Drums
I just got back from the machine shop and have bad news. So, I am in desperate need of a new set of rear brake drums for a 1971 Chevrolet 3/4 ton, 4x4 with an Eaton/Corporate Rear Axle.
Apparently this brake drum and hub assembly was only used ONE year. You can check your parts books (Wagner, Bendix), but it won't do any good. The GM parts number from1971 is #3996637. If anyone knows if I can swap backing plates and use drums from a 1972 I would greatly appreciate it. Please help. Thanks. |
09-05-2003, 08:05 PM | #2 |
Born Psycho
swap the drums, hubs, backing plates etc. from a 2wd 3/4 ton with an eaton rear. it'll all fit and works fine.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
09-06-2003, 12:40 PM | #3 |
Thank you Jerry, if anyone would know what to do, you would.
But, a couple things I thought of are will the bolt pattern of the backing plate match up or will I have to drill them to match? Also, is the spindle on the end of the axle tube the same to match the hubs and bearings? Thanks for your help... |
09-06-2003, 12:56 PM | #4 |
You might call them on Monday parts shows they have a set of drums . Parts search doesn't show if drums are for Eaton . They are closed today . I had a hell of a time finding a set about 10 years ago for a 71 4x4 that i had Good luck . Jose
http://www.northverdeautosalvage.com/ |
09-06-2003, 04:18 PM | #5 |
If you don't have your heart set on drum brakes. TSM mfg
makes a disk brake conversion kit thier web site is www.TSMMfg.com |
11-17-2003, 05:59 PM | #6 |
i have a set of rear drums off a 72 3/4 ton. pm me if you want em. also though http://www.echobit.com and http://www.azkickin.com both offer 14ff disc kits a lot cheaper than tsm. these will work just fine as it did on mine. everything is the same.
