Old 06-29-2015, 09:38 PM   #1
PeachesU
Over heating issues.
My thermostat housing had been leaking a little bit so the other day I decided to fix that, now prior to this I have not had any over heating issues whatsoever. I changed the gasket and that was it, well it stopped leaking but now it overheats in about 5 minutes if I'm driving it and ten if its just idling. I put in a new thermostat and another new gasket and it still is doing the same thing. I haven't changed anything else so should I get another thermostat and try it or is there something else that I should be checking? Any help would be appreciated.
PeachesU is offline   Reply With Quote
Old 06-30-2015, 12:41 AM   #2
70SBC10BOB
70SBC10BOB's Avatar
Re: Over heating issues.
What temp thermostat? Should be 160 to 180.
Did you drain the coolant when you did the thermostat?
Is the spring on the stat setting in the intake or the housing?? (Stat in backwards? Just a thought.)
1970 C 10 A work in progress!!
70SBC10BOB is offline   Reply With Quote
Old 06-30-2015, 07:40 AM   #3
cdowns
cdowns's Avatar
What exactly does it do that leads you to think it is overheating// is that a c40 year old gauge setup or are you taking an accurate measurement of the temp
Old 06-30-2015, 12:30 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Might not be the thermostat. Could be a 40 year old crud filled radiator too.
If it's only puking coolant out of the overflow hose, and not actually getting "hot" via a temp gauge... you've filled up the radiator too full. Rigs with radiators without an over flow tank and just a hose that directs coolant to the ground should be filled until the radiator is about 2" to 3" from the top.
Every time you refill it to the top, it will blow coolant.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-30-2015, 10:42 PM   #5
PeachesU
Thanks for all the replys and the help guys. It is the correct thermostat, I just had air in the lines and didn't take the time to bleed them out. Sorry for the rookie mistake. Thanks again for the help and it just goes to show you that if you ever need any help someone is always here to help you.
Old 07-01-2015, 12:30 AM   #6
70SBC10BOB
70SBC10BOB's Avatar
Good job, way to stay with it. Some times we just have to go back to basics and start over.
