Old 07-05-2015, 09:04 PM   #1
68wannabe
Addco rear sway bar
So is was thinking that the rear sway bar from Addco would mount in the pre drilled holes right below the mounts in the picture. It seems to me like the trailing arms, that have to be drilled, are at too much of an angle to drill on just the outside, or just the inside (if that makes sense). I could be wrong, but if somebody has installed one of these, just let me know. Thanks.
68wannabe is offline   Reply With Quote
Old 07-05-2015, 09:06 PM   #2
68wannabe
Posted via Mobile Deviceforgot the pic
Old 07-05-2015, 10:41 PM   #3
Jurassic-1
Jurassic-1's Avatar
Re: Addco rear sway bar
My sway bar is very similar. I purchased it probably 15 years ago from performance suspension. My top mount is similar but the bottom has a rectangular heavy plate with about a 4 inch wide bushing. It has 4 holes but because of the control arm angle only 2 diagonal holes are used and it has 2 thick tabs that pinch the plate to the control arm No drilling. It has never moved in 15 years.
Jurassic-1 is offline   Reply With Quote
