250 engine timing question
I have a 250 engine in a 68 swb stepper.
I have installed a hei conversion distributor, new plugs, wires, etc. I set the initial timing at 10* btc with vacuum advanced plugged. Runs fine there. Curious what others are running for timing on a similar set up? Is there any HP gains to be made with more advanced timing? Anyone pushing 12-14* btc settings. How's it run? I tried the search feature and really didn't find a good answer. Thanks in advance (no pun intended)
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: 250 engine timing question
I usually bump the spark plug gap up to the HEI specification and then, on a hot day, add more timing little by little until it pings and then back off. If I remember right, it's not a lot more than stock.
I can't remember where I got this, and I haven't tried it, but it sounds like it's worth a try:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
![]() Join Date: Sep 2001
You need to consider the total timing as provided by the mechanical advance. A stock 250 needs about 34 degrees of total advance. How much is built into the stock HEI?
Active Member
![]() Join Date: Jul 2007
Once you do the above recommendations, there's no reason you can't go up in small increments and see how the truck runs. I did that with mine.
After originally setting it at 10º BTDC, I went up to 12º and 14º BTDC. I'm now back at 10 since I didn't see any significant difference and it seemed to run smoother at 10 BTDC.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
It's right at 34* now set with 10* initial.
#6 | |
#7 | |
Thanks.
Post Whore
![]() Join Date: Mar 2013
Spec settings are 8 degrees advanced no vaccum. 20-25 degrees with vacuum. And no more than 36 degrees total no load. On my old 292 I set mine at 8 degrees and it made it a wee bit sluggish(not enough to care about) but made cold starts super easy. When I set it by ear I ended up having it almost at 14 degrees advance...the motor had such low compression it didn't matter and I ran 92 octane. 8-10 degrees is pretty common.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
