Closed Thread
Old 07-06-2015, 01:58 PM   #1
HSRACER
HSRACER's Avatar
Left turn equals both tail lights flashing???
So I just got a new to me 69 gmc and I was inspecting the lights before driving it home. Everything works properly until I put the left turn signal on. The front flashes fine but in the rear both sides are flashing. Right turn works properly with only the right side flashing in the rear.
I pulled the connection at the rear and found both lower pronged had flashing power to them which means that the problem is up stream of the actual tail lights and rear wiring harness. The factory leads along the frame are all ther and connected and the plugs at the firewall is solid and correct. It then seame to go to the steering column and the lower connection point which I thought was neutral safety switch?
Any advice of what to check next is appreciated!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline
Old 07-06-2015, 02:00 PM   #2
HSRACER
HSRACER's Avatar
Re: Left turn equals both tail lights flashing???
Sorry, posted twice by accident!
HSRACER
Slammed 53 5 window
HSRACER is offline
Closed Thread
