Old 07-07-2015, 02:47 PM   #1
aruss99
Rebuilt 350 not running under 1500 rpm
Hi all,
I recently rebuilt my 350 in my 1971 C-10, it has a mild cam in it as well as and Edelbrock Performer intake and Edelbrock 1406 carburetor. The problem I am facing is I cannot get the motor to idle under 1500 rpm. I have adjusted the idle screw so that the truck will still run without my foot on the gas. I then tried to lower the rpm that way but once the rpm got below 1300 rpm, the motor would start to die. I then tried adjusting the idle mixture screws at 1-1/2 turns out and tried adjusting the idle that way but no matter which way I turned the screws, no audible difference happened as well as no rpm change. I have not tried turning the screws super far out because I do not know much about carbuertors and didn't want to mess anything up anymore than it is. If anybody could shed a little light on what to do in order to get it to idle lower that would be great
aruss99 is offline   Reply With Quote
Old 07-07-2015, 03:16 PM   #2
geezer#99
geezer#99's Avatar
Re: Rebuilt 350 not running under 1500 rpm
Could be flooding.
Look in the carb. Any raw fuel says it's flooding.
Eddy carbs don't like more than 5 psi fuel pressure.
You might need a fuel regulator.
Old 07-07-2015, 03:23 PM   #3
DillonGMC
DillonGMC's Avatar
Torn carb gasket sounds like. Just dropped my brothers new engine in his camaro a couple weeks ago. Did the same thing. It had a washer on one of the studs under the gasket. I recomend one of the thick gaskets with the lead bushings in them. Also, if you are running an electric choke make sure it is hooked up. I've ran into that before. It sounds like Its drawing air from somewhere, you can spray ether around your carb base, intake gaskets, and any vacuum lines to find the leak.
The Pontiac V8: the original Super Duty.
DillonGMC is offline   Reply With Quote
Old 07-07-2015, 07:14 PM   #4
RodnRudy
RodnRudy's Avatar
Sure sounds like a vacuum leak to me. Check for missing vacuum plugs on carb and intake manifold.
RodnRudy is offline   Reply With Quote
Old 07-07-2015, 07:50 PM   #5
aruss99
Thanks for all the advice. I will check for vacuum leaks as soon as I can and let you guys know what I find.
Thanks again for the help
Old 07-07-2015, 09:02 PM   #6
aruss99
Hi all,
I was unable to find any vacuum leaks on the motor. I checked all the vacuum plugs as well as sprayed starter fluid around the carberatour to no avail. I am stumped on what I should check next.
geezer#99 said that my fuel pressure may be too high. Could the different cam have changed that? I don't know if that is a stupid question but I figured it is better to ask than just assume. Any explanation would be appreciated
As usual, thanks for all the advice.
Old 07-07-2015, 10:36 PM   #7
geezer#99
geezer#99's Avatar
Originally Posted by aruss99 View Post
Hi all,
Eddy carbs are known to be fuel pressure sensitive. THey don't tolerate more than 5 psi. Higher pressures keep the needles off the seat and it floods.
Simple way to check is look in the carb.
Should be no raw fuel visible while idling.
Your mild cam plus other mods also need more timing.
Old 07-07-2015, 11:09 PM   #8
RatPwrd72
RatPwrd72's Avatar
Need to check the timing when it's at a point it'll run as well as look for vacuum leaks.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 07-07-2015, 11:18 PM   #9
aruss99
Thanks for the help, I went out to check the fuel and whenever it started to run it started shooting fire out of the carb which leads me to believe that it is indeed getting too much fuel. Is that a correct assumption or am I wrong?
Old 07-08-2015, 12:07 AM   #10
geezer#99
geezer#99's Avatar
THat means your timing is retarded!
Forget the fuel right now.
Loosen the dizzy and rotate it ccw about 1/2 inch. Then try it running. If it gets better keep advancing it. When it will idle and not backfire, lock the dizzy down and check for fuel, adjust the idle down and adjust the mix screws.
Old 07-08-2015, 11:56 AM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Then get a timing light and adjust the timing properly.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-08-2015, 11:59 AM   #12
DillonGMC
DillonGMC's Avatar
X2 on a timing light.
Old 07-08-2015, 06:14 PM   #13
aruss99
Okay thanks for the advice. I will get to it as soon as possible and let everyone know what I find.
Thanks for the help
Old 07-08-2015, 10:36 PM   #14
aruss99
Thank you for your help. I was able to advance the timing enough to get it to idle under 1k rpm, so problem solved. I appreciate your insight as I'm only 15 and have not had the opportunity to learn these kinds of things yet, but you learn something new everyday.
Again, thanks for the help
Old 07-08-2015, 10:41 PM   #15
geezer#99
geezer#99's Avatar
Not solved yet!
You need to get the idle below 800rpm. The mechanical timing in the dizzy kicks in at 850 ish.
You're likely still not idling on initial timing yet.
Old 07-08-2015, 10:48 PM   #16
aruss99
Not solved yet!
Okay, I'm sure I can get her there. I stopped lowering the idle around 900 rpm because I had to manually keep the dizzy from moving as it wasn't tight. Ill lower it to around 700 rpm since that was what the motor ran at before the rebuild.
Old 07-08-2015, 11:01 PM   #17
geezer#99
geezer#99's Avatar
You're doing good for a 15 year old!!
When I was your age I was helping the hotrodder next door put a new timing chain on his 427 Ford S.O.H.C.!!
Now that's a timing nightmare!! LOL!!
If you don't know what that is, google 'Single Over Head Cam for a 427 Ford.
Old 07-08-2015, 11:08 PM   #18
aruss99
Thank you, and will do
Old 07-09-2015, 01:39 PM   #19
snipescastle2
snipescastle2's Avatar
Talking Re: Rebuilt 350 not running under 1500 rpm
might have been said already, but did you check the intake manifold for leaks? I'd try to retorque the intake just to make sure, maybe spray some carb cleaner there too.....
HTH,
Ben
snipescastle2 is offline   Reply With Quote
Old 07-10-2015, 06:37 PM   #20
MagmaJct
MagmaJct's Avatar
I am reminded of the animated fire in that in the Lego movie.
I can say that in the 20 years I've been working on my own carbureted vehicles, I have NEVER had a fire of any kind. With that being said, as others have mentioned, apparently the timing can cause this. Although, I'd find it hard to believe the engine could even run with it that far out.
My advice to you, coming from someone who was once 15... Take some automotive classes in high school. I took it for two years. Then, take a college course or two. I took one semester.
I hope they at least teach carburetor theory still. Fuel injection makes so much more sense if the carburetor theory is taught well, including the limitations of carburetor metered engines.
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
