Old 07-08-2015, 12:37 PM   #1
9teen69
9teen69's Avatar
72 brake line clamp colors
I have search and search...
What is the factory correct colors for the brake line clamps?
Installing SS lines and de-greased and stripped most of the paint. Wanted to get the clamps back to the factory colors or close to.
I have 3 redish ones that run along the RH rails next to fuel lines
2 that look green, can hold two lines
1 white one, can hold two lines
2 bare metal, can maybe hold two small lines
2 bare metal, 1 line
1 bare metal, 1 3/8 line
thanks
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 07-08-2015, 01:41 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 brake line clamp colors
Suspect they're either phosphate coated (Parkerized) or maybe galvanized but not painted. I'd favor phosphate coated. Zinc coating would replicate galvanized more-or-less. Would be easy to send these with other parts for coating in either finish. Here's an example pic of both finishes: http://67-72chevytrucks.com/vboard/s...7&postcount=77
Old 07-08-2015, 02:28 PM   #3
Bigdav160
Bigdav160's Avatar
Definitely green and red. I did not make any notation on what clamp held what.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-08-2015, 03:49 PM   #4
dfwright
dfwright's Avatar
On my 72, I had 2 green ones, 3 red ones, and a white one which went down the rails on the passenger side. These held the gas line and vapor lines.
The bare metal ones were used to hold the gas return line, and the brake lines, both down the rail, on the cross-member, or where the brake line attaches to the underside of the frame as it goes down to the cross-member.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 07-08-2015, 07:41 PM   #5
9teen69
9teen69's Avatar
Deadhead- yeh I have that post saved, definitely going to use them in he future.
Dfwright- that's awesome the white one was kicking my butt. Thanks!
Bigdav- you should save these images thanks
So the two on the drivers frame where it goes out and up to master cylinder are bare metal ?
I'm painting them Eastwood silver cad and flat black ...poor mans zinc and phosphate
Old 07-08-2015, 07:50 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good info here - thanks fellas
Old 07-09-2015, 12:22 PM   #7
dfwright
dfwright's Avatar
These I believe to have been bare metal, yes. They were gunked up and rusted over on mine, so I have no reference for any color on those. I painted mine silver/metallic.
Old 07-09-2015, 08:34 PM   #8
9teen69
9teen69's Avatar
That's how i painted them...thanks!
